Torque Settings for Alloy Wheels - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 9th, 2002, 02:45 PM
timlowden771's Avatar
Local Time: 06:34 PM
Question Torque Settings for Alloy Wheels
I know this is a bit of a sad question, but I have just taken the mud flaps off of my Mini becasue the road works have finished down my road, and I was wondering if anyone knows the torque settings for the wheel bolts. I have the 16' 5 spoke alloys. Any help will be greatfully received?
If she's not smoking she broken!
Old Apr 10th, 2002, 09:52 AM
chiph's Avatar
Spectator
Local Time: 01:34 PM
United States View chiph's Electric Blue & White 1st Gen MINI Cooper S Profile
Most passenger cars are 60 lb-ft (which I think is 80 N-m). This is easily acheived using the MINI-supplied wrench and applying your upper-body weight to the very end of the wrench. Most people are surprised at how little it actually takes to tighten them to spec.
Make sure mechanics don't use air wrenches to tighten your bolts, especially if you have the anti-theft wheel bolts. It may result in their having to be drilled off (happened to me on an earlier car).
Chip H.
ex-MINI Cooper S owner and all around good-guy
Old Apr 10th, 2002, 12:55 PM
karmuze's Avatar
Local Time: 05:34 PM
The torque number for lugnuts is basic owner's maintenance information that should be in the owner's manual for the car. I am disappointed that it is not there. For the VW Golf I owned that had 17mm bolts the recommended lugnut torque was 85 ft-lbs (115Nm). For my Volvo with 19mm bolts it was 90 ft-lbs (120Nm). What size are the wheel bolts on the MINI?
You could call your dealer and ask a mechanic to look up the proper number in the MINI maintenance manuals, to be sure.
Jerry
Old Apr 10th, 2002, 03:04 PM
Apial's Avatar
United Kingdom Male View Apial's Lightning Blue & Silver 2nd Gen MINI Cooper Diesel Clubman Profile
Why don't you ask M***M*******Ad***r.
Oh well in case she doesn't know and is too busy selling MINIs the answer to your question is 105Nm or 75ftlb for alloy AND steel wheels.
Old Apr 11th, 2002, 09:55 AM
chiph's Avatar
Spectator
I stand corrected as to the torque spec.
Chip H.
Old Apr 12th, 2002, 09:51 PM
ADO15's Avatar
Norway
Mind if I aske where these figures come from?
"Life begins @ 7,000 rpm's"
Old Apr 13th, 2002, 04:16 AM
Apial's Avatar
Talking Torque.
These figures came from my MINI dealer, however, if you look at page 128 of the Owners Handbook you will see the torque setting of 100 Nm for the compact spare wheel. Why the difference? No idea, but its only 5Nm difference. I do know that the mechanics always apply a lot more torque than 105 Nm as I need to apply a far higher torque to remove the wheel studs. Better safe than sorry I guess.
Old Apr 13th, 2002, 10:39 AM
chiph's Avatar
Spectator
Re: Talking Torque.
Well, to a point. If you over-torque the lug bolts unevenly you run the risk of warping the hubs, and in extreme cases you may never get the bolts off again (will need to be drilled off).
I was also going to say you'd have the joy of struggling with the wrench while changing a flat by the side of the road during a rainstorm... but with runflats (and no spare!) that's not likely to happen anymore.
Chip H.
Suspension Torque Settings Minnington First Generation MINI Suspension 1 Sep 8th, 2006 12:41 PM
oil & filter change help with torque settings S-Cooper Maintenance & MINI Care 2 May 21st, 2002 04:57 AM
new alloy wheels iabbott First Generation MINI Exterior 4 Feb 18th, 2002 03:20 PM
Alloy Wheels ? Pezza First Generation MINI Exterior 6 Jan 4th, 2002 02:31 PM
