| hey, i want to get my mini cooper( with aero kit) lowered 30mm possibly all round but at the moment its only on 15's. I do plan to get a set of 17's (when I can afford them), but does anyone think lowering it 30mm is too much on small ( and rubbish) wheels? Any info or pics would be good. Thanx This site is getting addictive! |
| Yeah im not so sure there would be plenty of room lowering 45mm on 15's either. Ive already bumped it a few times, so i might have to drive slower over those blasted speed bumps. Looks is what counts tho! Thanx for those pics Ben. ( i hope ive got ur name right). |
| you are correct bud, ben it is. dont get me rong ppl, i dont scrape or rub anywhere, nor do i expect to on 18's (after a small steering mod done by BMW to reduce lock) but my front bumper cates on everything, multi stories, speed bumps, driveways, dip in the road..........cats eyes 50mm?!?! thats immense!! ![]() HATED BY MANY...LOVED BY FEW...RESPECTED BY ALL |
| Never afraid to ask a stupid... Why does the size of the alloy make a difference? The overall circumference of the tyre is the same, is it not. I.e. larger alloy simply means lower profile tyre... or is this not the case for the Mini? Pete 2010 Cooper S. |
| Pete, When choosing larger wheels and tyres it is recommended that you stay within + or - 3% of the original tyre rolling diameter. This means you don't upset the suspension geometry, handling, speedometer reading etc. too much. As you say this is done by using a lower profile tyre if you have increased the wheel diameter. The problems are associated with the extra width that accompanies larger diameter wheels. The extra width is mostly on the outside of the wheel bringing the outer edge of the new tyre much closer to the edge of the wheel arch or bodywork. In addition a lower profile performance tyre will usually have a more square shoulder on it that compounds the problem even further. Hope this helps, Alan W |
| Advice on lowering, 20mm or 30mm? | R99 | First Generation MINI Suspension | 14 | Aug 31st, 2007 08:27 AM |
| lowering 30mm whats the rub? | alski | First Generation MINI Suspension | 6 | Jun 12th, 2007 05:47 PM |
| 30mm lowering question | Richard22b | First Generation MINI Suspension | 30 | May 31st, 2006 08:44 PM |
| 30mm lowering on s suspension? | mutilator | First Generation MINI Suspension | 31 | Apr 3rd, 2005 04:31 AM |
| 15's on a S?? | ALD0 | First Generation MINI Cooper S | 6 | Apr 25th, 2004 06:21 PM |
