Dual Tail lights with Fog lights?? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 5th, 2004, 03:09 PM
Mugami's Avatar
Local Time: 01:36 PM
United States View Mugami's Dark Silver & White 1st Gen MINI Cooper S Profile
Hi guys. I was wondering has anyone done the Dual Brake light conversion (Popular with US spec cars that dont have rear fog lights) but retain the working Rear Fog lights (lamps). I had the Dual Brake lights. but then had the rear fog light retro fitted so i can have all the switches on the dash. Which meant going back to a single brake light. Been working on a conversion to allow me to have both the rear fog light and dual brake lights at the same time and was wondering if anyone else would be interested when im done?
02 MCS DS/W (Totaled November 02 on Fall Folage Run)
03 MCS DS/W (See my MINI Profie for extensive list of mods)
Old Aug 5th, 2004, 03:42 PM
Local Time: 11:36 AM
United States View tom bolin's Dark Silver & White 1st Gen MINI Cooper S Profile
I just did this to my MCS, check out this web site, www.littlemini.us there is a diode brake light link that should be able to help you.
tommyb
Old Aug 5th, 2004, 10:47 PM
Mugami's Avatar
The mod shown is the common one used if you dont have Rear Fog lamps which can be turned on by the driver. Which most US spec cars dont have. What ive done is make it possible to have both the rear fog lamps and dual brakes at same time.
Old Aug 6th, 2004, 01:14 AM
CoryB's Avatar
United States Male
The fog lights use a single filament bulb. As such there's no way to have them lit and then get brighter as secondary stop lights when you step on the brakes.
By using the diode mod, which is essentially a one-way valve, the stop lights don't come on when you turn the fogs on. The rear running lights are not affected. Using just a paperclip or wire splice, the stop lights would come on whenever you turned on the rear fogs because current would backflow to the stop light filament.
His - 04 CR/W MCS
Hers - 05 BEP/W MCS
Old Aug 6th, 2004, 10:33 AM
Mugami's Avatar
Thank Cory.. i forgot thats how the diode worked. Its been to long. Btw what i rigged up was a relay to do the same thing. Its just me i perfer mechanical means over electronic for some reason.
Front Driving Lights inplace of Fog lights brett First Generation MINI Exterior 29 May 8th, 2004 10:07 PM
Using installed Rear Fog Lights as Fog + Extra Brake Lights. Possible? averyocooper First Generation MINI Exterior 4 Mar 3rd, 2004 07:09 PM
convert rear fog lights to run/break lights bobw First Generation MINI Exterior 2 Jan 1st, 2004 01:31 PM
Side lights looking similar to Fog lights? ALD0 General Discussion 2 Sep 29th, 2003 10:44 PM
Did you know the 7-Series has Rear Fog Lights that double as emergency brake lights? BruceK General Discussion 7 May 7th, 2003 03:30 AM
