| have a look at this thread, http://www.mini2.com/forum/first-generation-mini-exterior/70070-removal-front-indicator-fog-lights.html Don't know if you'll have the wiring if your fitting them for the first time. Regards Mick |
| I was at Prestige MIni in NJ here in the states and they could *NOT* for the life of them figure out how to install the fog lights on this particular car they were working on. For some reason the wiring was all messed up. If a reknown dealer (which I think of highly of personally as they are the only exclusively-Mini dealer here in the tri-state area as far as I know of) has trouble installing them, I would suggest not doing it yourself. I wouldn't do the fogs myself and I've done a TON of other things to my car......... "Do or do not. There is no try." - Master Yoda |
| Installing auxilliary lamps is not a difficult project, and of course depends on your skill level and experience. If you install them, be sure to use correct wiring and relays on each lamp circuit. Complete wiring looms for fog/driving lamps are available at lots of retail outlets. My dealer's price for the '05 MCS driving lamps is RIDICULOUS at $650 U.S. Such a price is good motivation for installing them yourself. Good luck, let us know how it goes. |
| I believe he is talking about the fog lights that are integrated into the bumper, not the driving lights that you install on the grill of the hood. Again, I do not recommend that you install it yourself. "Do or do not. There is no try." - Master Yoda |
| I recently added a set of fog lights on my 03 MC. I got the fog light kit from Classic Mini for about $150. The kit includes the fog lights, wiring harness, relay & fuse, new switch panel and some replacement clips and cable ties. Instructions are not included but can be found on the web. http://motoringfile.com/howto/Fog%20Lights.PDF According to the instructions this is a 2 hour installation. I found it took me about twice that long but I took my time and did it in two parts; the under the hood work one day and then the under dash work a couple of days later. There is no need to remove the bumper, the fog lights go in from behind after the wheel well liner is removed you also need the liner out to run the wires to the fog lights. A numbers of the wires get installed into existing plugs in the fuse block and body control module so you need to be a bit careful to get the correct pin locations. Running the wiring through the firewall was also a bit of a fiddle but there is a provision in the existing molded rubber boot where the main harness goes through for additional wiring. This is good bit more challenging than changing oil or brake pads but probably no harder that installing a new radio head unit and speakers. The install kit has everything you need and it all fits. You can get a feel for what is involved by reading the instructions. My car goes in for programing next week so we will see if it all works soon. Updated - car went to the dealer today for programing and everything works great. At first the dealer thought that the front fogs should work without programing, but agreed to try programing the front and rears; afterward both worked OK. I'm happy with the results and would do it again. The price for the kit seems reasonable and the new switch panel included the rear fog switch, no wiring required, only programing is needed to enable this feature (not a normal option for this side of the pond). Hank Last edited by Hank195; Oct 13th, 2004 at 02:58 AM. |
| Fitting fog lights | IH1 | First Generation MINI Exterior | 3 | Jul 10th, 2006 08:03 PM |
| Retro Fitting Fog Lights to 2002 MCS Help needed | zanhar25 | First Generation MINI Exterior | 9 | Feb 22nd, 2006 08:42 PM |
| Fitting Fog Lights - is it hard to do ? | DCM | First Generation MINI Exterior | 3 | Aug 11th, 2004 11:47 AM |
| Fitting Fog Lights | theminiv | First Generation MINI Exterior | 6 | Apr 17th, 2004 05:28 PM |
| Using installed Rear Fog Lights as Fog + Extra Brake Lights. Possible? | averyocooper | First Generation MINI Exterior | 4 | Mar 3rd, 2004 07:09 PM |
