Any Existing MCS Engine Sensor Support ???? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 6th, 2005, 03:59 AM
MadHatter's Avatar
Local Time: 10:07 AM
United States View MadHatter's Classified Ads
United-States Any Existing MCS Engine Sensor Support ????
I am getting ready to install gauges in my 2005 MCS. I am planning on installing oil temp and water temp in the gauge pod that has the two gauges under the radio, and soon after oil pressure and oil boost on the pod that stradles the tachometer.
I am trying to find out if the car is pre-configured in anyway for the tempurature sensors, or the oil pressure / boost gauges since I know that mini offers some extra gauges in the accessory catalog.
Does anyone know if either wires or plugs, or other hardware are already in the engine. Or is this an experience where I will need a shop to drill, tap and install wires from scratch for some or all of the sensors.
Thanks for any assistance,
- MadHatter
Old Jan 10th, 2005, 02:32 AM
eurekame's Avatar
Send a message via Yahoo to eurekame
Local Time: 01:07 PM
United States View eurekame's Pepper White & Body Color 1st Gen MINI Cooper S Profile
As far as I can tell there is no prewire for any of those gauges.
I purchased but have not installed the factory oil temp/voltage gauges. (I'm working on the install for the boost gauge) The install kit came with the wiring for both of these gauges. The boost gauge vacuum line connects under the inter-cooler and the oil temp sensor replaces the drain plug. The voltage gauges just taps into the cig. lighter. There are no accommodations for oil pressure as best as I can tell from reading the related forums. I have the factory PDF instructions for the oil temp/voltage set up. PM me and I will send it to you. Thats how I got it. I have found no problems getting wires or tubing thru the fire wall. Penty of grommets to choose from. There a plenty of threads on wiring up the gauges and the lights for them. good luck.
Don't Panic
Old Jan 12th, 2005, 07:08 PM
Local Time: 05:07 PM
made by mini?
04 Fully loaded 18" Hartge UJack. Hamann lip& diffuser. Mini AeroSides. 7000k. ProMini-spark wires, strut bar, intake+HKS filter, 19% pulley, Superchip.uk ECU. Borla Race. SSprint Header Catless, MMadness camber plates Eibach ProKit. 22mm Alta Sway
Brake pad sensor Q on 02 MCS texascadillac42 Wheels, Tyres & Brakes 1 Sep 11th, 2006 07:49 AM
Brake Light Sensor & Sensor replacement help needed wrxtomini First Generation Faults & Fixes 7 Apr 20th, 2006 08:55 AM
Service Engine Soon - oxygen sensor software update available paulr First Generation Faults & Fixes 0 Jul 2nd, 2005 12:42 AM
I opted for Rain Sensor on my MCS, soo.......? Ibb General Discussion 16 Feb 27th, 2005 10:04 PM
Oxygen Sensor or Coolant sensor???? maximusrp First Generation MINI Tuning 5 May 30th, 2004 07:33 PM
