05 MC with 04 MCS bumpers - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 21st, 2005, 11:55 PM
danbanger's Avatar
Surf and Destroy
Local Time: 10:40 AM
United States View danbanger's Chili Red & White 1st Gen MINI Cooper Profile
Well I recieved my bumpers today and installed them. Front bumper installation went well but the rear doesn't. The problem is I need to take my MC rear valences to put on the MCS bumper but the valence doesn't line up with the MCS bumpers.
Before:
!!@#!@# Caution 56k https://home.comcast.net/%7Emtown408x/mini3.JPG
After:
And heres the rear bumpers and you can see why I'm having a problem with lining up the MC valence with the MCS bumper.
What should I do? Would an '04 (or earlier) model rear valence for a MC fit on the 04 MCS rear bumper? Thanks.
Old Mar 22nd, 2005, 06:01 AM
danbanger's Avatar
Surf and Destroy
anyone?
Old Mar 22nd, 2005, 05:23 PM
centre exit's Avatar
Local Time: 06:40 PM
England View centre exit's Thunder Blue & White 1st Gen MINI Cooper S JCW GP Profile
Blue Cooper
yes, the 04 or older cooper bumper vallance (the black bits)
will fit the cooper s bumpers.
when i had my cooper i fitted cooper s bumpers to it and it
looked good.the only thing i found that i needed to fit all three
pieces of the vallance as the s type are thicker.
hope this is of some help.
lee.
Old Mar 22nd, 2005, 06:09 PM
danbanger's Avatar
Surf and Destroy
lee.
Thanks. Are you saying that I cant use the side bits of the MCS, so I'll need all three bits of an 04 model MC valence or later?
Old Mar 22nd, 2005, 06:18 PM
thats right,
you cant use the centre piece as its for a centre
exhaust so it means that the two side pieces wont match up to
it as the are "thicker".
unfortunatly you will have to replace all
three bits.
is it possible that you could sorce them 2nd hand?
but saying that they might not that expensive new!
Old Mar 22nd, 2005, 07:15 PM
AndrewBradbury's Avatar
United States View AndrewBradbury's Chili Red & White 1st Gen MINI Cooper Profile
I just replaced the rear bumper on my 05 MC thinking that I'd only need to replace the center trim piece, but you need the two side pieces too, as center exit says. I assumed the 05 and 04 MC trim pieces would be interchangable, but apparently not (there's about half an inch over overlap where the wheel arch trim and bottom trim meet). The good news is that the trim pieces are really cheap, less than $20 for the whole set.
Danbanger, have you considered replacing the chrome grille pieces on the bonnet? I'm in the process of doing that too, and I think it'll look good when it's done - plus the upper and lower grilles on your would match
Old Mar 23rd, 2005, 03:20 AM
danbanger's Avatar
Surf and Destroy
Yup, I plan on replacing the chrome grills too at some point. I'll be calling the dealer about the bits tomorrow, thanks for letting me know that I need all 3 bits.
Everyones help was greatly apreciated.
Old Mar 23rd, 2005, 05:27 AM
If you can get a hold of the grille bits used, I'd opt for that... I got a quote for $200 for the single lower grille part alone! That's $200 for a painted piece of molded plastic worth maybe $5. They wouldn't even sell the upper part in anything other than primer. I'd also advise getting the plastic mounting part that the grille attaches too, as I couldn't seperate the grille from that part - it was $36 from the dealer.
I can get the part number for that tommorow if you need it. Good luck on removing the upper grille assembly, it's not the easiest thing; I broke several of the plastic bolts that secure it removing it.
Old Mar 23rd, 2005, 09:38 AM
danbanger's Avatar
Surf and Destroy
Wait I was talking about the aero black grills sorry
But if you were talking about these, I think you can get them online from websites such for about 80-100 usd
Old Mar 23rd, 2005, 05:03 PM
Ahh, I was misunderstanding. Please post some photos with the aero grille installed, I'd love to see. I was considering doing the same to mine.
fitted my mcs bumpers Mini One`S First Generation MINI One 0 Apr 19th, 2006 05:04 PM
MCS Bumpers Daley Express First Generation MINI Exterior 0 Jan 11th, 2006 06:55 PM
Fitting 05 MCS bumpers to 01 ONE danb First Generation MINI Exterior 5 Apr 27th, 2005 06:03 PM
Cooper bumpers on an MCS vdubdoug First Generation MINI Exterior 0 May 24th, 2003 07:51 AM
