Does anyone know a dealer that will fit 4 spots - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 19th, 2005, 06:24 PM
Local Time: 05:41 PM
England
Question Does anyone know a dealer that will fit 4 spots
I've just had my latest cooper fitted with one pair of spots and while with the black covers it looks smart ,it doesn't look half as good as my last cooper with 4 spots. I've tried both my local dealers and both have refused to fit a second pair, though I've heard some dealers are still fitting them. does anyone know a dealer in the midlands still willing to fit an extra pair?
ON A MISSION FOR MR BRIDGER!
Old May 1st, 2005, 12:10 AM
Mini-Trainer's Avatar
Morph-a-Doodle
Local Time: 06:41 PM
United Kingdom Male View Mini-Trainer's Pepper White & Black 1st Gen MINI Cooper S Profile View Mini-Trainer's Classified Ads
Lousy Stinkers
I believe BridgeGate at Chesterfield and Paragon in Hull do
Rams
Old May 1st, 2005, 08:35 AM
StevePSB's Avatar
Send a message via ICQ to StevePSB Send a message via MSN to StevePSB
England
No dealer should. There was an official MINI dealer bulletin saying that 4 shouldn't be fitted for excess light and possible airflow restriction problems.
Old May 1st, 2005, 09:18 AM
randap's Avatar
Hangin at the Krusty Krab
United Kingdom Male View randap's Solid Black & Body Color 1st Gen MINI Cooper Profile View randap's Classified Ads
Who will fit 4 spots?
Bridgegate Derby will, but will only wire one set. Apparently there's no airflow problem, it's the potential for overpowering the electrical system. I was told at Bridgegate Derby that if you wire up the second set yourself, TLC will be unaffected, but if you have any waranty claim regarding electrical items it will be rejected by BMW, even if unrelated to spots.
So, I might get a second set fitted. Purely for cosmetic purposes obviously.....
Old May 1st, 2005, 09:12 PM
RVW's Avatar
RVW
003 On a Mission
Online
United Kingdom Male View RVW's Hot Chocolate & Silver 2nd Gen MINI Cooper Diesel Clubman Profile View RVW's Classified Ads
I never had a problem when I got my dealer to supply and fit my second set He was happy to take the money and give me a receipt
Old May 3rd, 2005, 12:12 PM
United Kingdom View AERO MINI's Classified Ads
I think Paragon in Hull will fit 4. They wanted about £750 to fit 4 to my mini cooper so I opted for just the 2.
Old May 3rd, 2005, 01:25 PM
PortRhombus's Avatar
MINI2 Irregular
do it yourself. it isnt hard to do. it will save yourself a handsome sum.
i have four spots across the front of mine all working. fitted it all myself with no hassle.
i paid £210 all together and thats it.
Old May 3rd, 2005, 07:08 PM
England
Can you just wire the the second set in parallel to the first? and do the second set still have to be activated by BMW when you fit them??
Old May 4th, 2005, 11:05 AM
MINI2 Irregular
The second set of spots wires exactly the same as the first. So dont worry about any fuses blowing due to extra lamps. Each set has its own fuses and draws there own power.
The only difference is the brown wire which normally leads into the control box from your relay needs to be spliced into the exsisting brown wire from your first set of spotlamps.
This way both relays are activated when the high beams are switched on.
If your spots are already on and programmed in by your dealer they dont need to be programmed again. The programme would be the same.
Does that make sense?
How easy is it to fit Spots yourself R60 Mike Second Generation MINI Exterior 4 Jun 2nd, 2007 11:02 AM
Spots fitted at dealer - but not working. Advice? R99 General Discussion 4 Apr 10th, 2007 11:25 PM
Dealer Program spots lights Blackaeromini First Generation MINI Exterior 3 Jan 29th, 2005 02:51 PM
JCWs Kit Factory Fit or Dealer fit what route would you go if you had a choice.!! dinger First Generation MINI Cooper S 13 Jul 17th, 2003 07:12 PM
JCWs Kit Factory Fit or Dealer Fit dinger First Generation MINI Cooper S 0 Jul 16th, 2003 07:31 AM
