» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > MINI Technical Forums > MINI Exterior > First Generation MINI Exterior
First Generation MINI Exterior First Generation MINI Exterior 2001 - 2006
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
Old May 13th, 2005, 09:03 PM
The Works's Avatar
The Works
Local Time: 11:07 PM
England
BMW White Lights, how to change brake light bulb?
This may seem a silly question but how do you change the brake light bulbs in the BMW White lights?
I've just sold mine as I never got round to fitting them but the guy who's fitting them can't seem to get the brake light bulb out (sealed unit?).
Michael
210bhp Works Cooper S and 550bhp Ultima GTR
www.ultima-gtr.co.uk
Old May 13th, 2005, 09:14 PM
cooperstan's Avatar
cooperstan
United Kingdom View cooperstan's Pepper White & Black 1st Gen MINI Cooper S Profile
As I remember when I fitted mine, the bulbs are soldered to the bulb holder. The bulb holder itself is seperate to the lamp but it looks like individual bulbs cant be replaced and you have to change the whole unit, i.e the holder the bulbs actually fit into, god only knows why. He may have to change the entire holder or unsolder the bulb...
I've kept my old lights so I can use the old holder in the clear lamp unit when the bulbs blow. The same bulbs as fitted in the white light kit are available from most car shops.
Hope that makes sense, my old lamps arent here otherwise I would take a picture.
Pepper White/Black Cooper S GTT210
Milltek Exhaust, Cooper Motorsport Strut Brace, Eibach Springs.
Old May 13th, 2005, 09:18 PM
The Works's Avatar
The Works
England
Cheers cooperstan,
Don't suppose anyone does have pics of this so I can send them to him.
Michael
Old May 13th, 2005, 09:21 PM
ALD0's Avatar
ALD0
Local Time: 10:07 PM
United Kingdom Male View ALD0's Hyper Blue & Black 1st Gen MINI Cooper S Profile
Thats correct-They are soldered for some stupid unkown reason! Though it might be fairly easy to remove with a solder iron?
Alternatively like cooperstan said, obtain a set of original pre 05 clusters off Ebay-Usually £20+Postage then swap the bulb holders across, you will have to buy the various buls though, Brake , Fog indicator etc in with silver coating like the ones in there now.
Only thing else could suggest is take them back to dealer and play hell that this is the most stupid design you have ever seen and you want replacements!
www.totalmini.com
Old May 14th, 2005, 09:05 AM
StevePSB's Avatar
StevePSB
Send a message via ICQ to StevePSB Send a message via MSN to StevePSB
England
Not sure that would go down very well... It's not the dealers fault. If the lights are less than two years old and you have your original receipt (assuming they came from a dealer) then they'll be covered by warranty.
Old Aug 24th, 2008, 01:21 AM
Local Time: 05:07 PM
United States Male
United-States Replacing brake bulb in Cooper S
I know this is way too late for you, but hopefully this helps others.
Just replaced the brake bulb on my '06 Cooper S. Here's the blow-by-blow:
1) Opened the access panel
2) Unscrewed the 10 mm hex nut holding in the brake light assembly
3) Detached the cable harness, pressed in the retaining springs and removed the assembly
4) Squeezed the clips to remove the bulb board (holding 3 bulbs) from the lens cover
5) Removed the brake bulb from the board (press in and rotate ~ 45 degrees)
Installation is the opposite of removal.
According to my Bentley manual, owners of convertible Coopers need to replace the entire assembly.
Old Aug 24th, 2008, 09:54 PM
ALD0's Avatar
ALD0
Think thats for the normal lights not the White lights where BMW soldered all the bulbs to the light circuit board
www.totalmini.com
Old Sep 16th, 2008, 02:59 AM
United States Male
Ah, never realized there was an option when it came to the tail lights, and had not noticed any difference when it came to the lights on the 02-06 Minis. I'll be keeping an eye out for them... I'm interested to see what they look like.
Fog light bulb change Jenga First Generation MINI Exterior 1 Sep 2nd, 2005 12:08 AM
BMW Clear/White Rear lights with 3rd Brake light Phoenix General Discussion 1 Mar 25th, 2004 09:01 PM
Bulb Replacement (brake lights in white tail light cluster) snarl General Discussion 3 Dec 26th, 2003 04:05 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
