Connecting PIAA driving lights - Which wire is the high beam wire? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 22nd, 2005, 04:52 AM
orbeamike's Avatar
Local Time: 09:44 AM
Hi,
I am in the process of fitting MINI specific PIAA driving lights kit to my 05 MCS and I have run into a little bit of confusion. The wiring seems straight forward except to connect the switch power wire of the PIAA light kit to the high beam wire ( I only want to be able to turn the PIAA lights on and off when high beam is on). The wiring diagram indicates "white with red dots" next to the switch power wire, except I can't find "white with red dots" anywhere in the car that I can see. There are 7 wires going into the lamp assembly and non of them are "white with red dots"
So which wire do I connect the PIAA swith power wire to? For those of you with PIAA lights can you take a picture or a detailed description exactly where to make the splice.
THanks very much in advance!
Mike
Old Jan 11th, 2011, 07:19 PM
winterv's Avatar
Loves his mini!
United States Male View winterv's Classified Ads
Does anyone know if these same lights can fit an R56? What if I buy the factory brackets?
Spot Lights, How To Wire In??? rushwood First Generation MINI Exterior 9 May 29th, 2006 09:14 AM
O2 sensor signal (High) wire.... which one? NFCooperS First Generation MINI Tuning 3 May 10th, 2006 02:19 PM
driving lamp re-wire tips please yiano First Generation MINI Exterior 7 Feb 11th, 2005 12:52 AM
The green wire or red wire? Sharkey General Discussion 2 Nov 21st, 2003 11:39 AM
Interior lights (under dash) how to wire? jivecar First Generation Interior & Ice 0 Mar 9th, 2003 01:33 PM
