Help engine keeps cutting out! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI One Diesel > First Generation MINI One D
First Generation MINI One D MINI One Diesel 2003 - 2006
Old Mar 7th, 2008, 11:41 AM
Local Time: 05:45 PM
Hi fellow Diesel owners!
I have had my Mini diesel for 2 years now and recently had a few probs:
The EML and diesel pre-ignition light (D??) come on when driving (normally fast 85mph and after about 10 to 15 miles), This brings the car to a halt and after a few minutes I can re-start it with no probs.
The BMW garage said it was the 2nd stage of the fan not working. So I had that replaced 2 weeks ago and now it had done it again!
Anyone had the same problem or knows what it might be?
Lee
Old Mar 7th, 2008, 11:47 AM
Could this be it?
The pas pipe to pump is also leaking (pipe to turbo). Could this be it? It does only happen at high speed and there is no rise in the water temp?
Odd and getting very expensive.
Old Dec 2nd, 2008, 09:35 AM
DIY I also have a similar problem - Engine Cutting out
Did you solve this problem?
My 2003 1.4D engine cuts out when under accelleration usually above 3000 rpm. A quick on-off with the ignion switch allows me to restart the car straight away. This can happen 4-5 times in a 10mile trip.
It has 1 OBD code strored P3002. I believe this is something to do with the engine ECU?
Can anyone help any furthur please?
Old Dec 6th, 2008, 10:44 PM
Send a message via MSN to Jinkster Send a message via Skype™ to Jinkster
Local Time: 06:45 PM
United Kingdom Male View Jinkster's Chili Red & Body Color 1st Gen MINI One Diesel Profile View Jinkster's Classified Ads
Had the same problem, change the fuel filter - cost me £25 from a local place (not main dealer) and its fitted behind the wheel arch on the opposite side of the car to the fuel filler cap.
Enjoy!
Old Feb 3rd, 2009, 07:58 PM
Isle of Man Male
Hey i know this is a bit late in the day but did u manage to sort out this problem at all? I have a similar one.
When the engine is below full working temperature and revved above 3000rpm the traction control light comes on and remains on. At the same time the engine goes into a 'get home safe' mode. Also the traction control doesnt work after this happens.
Any ideas?
Tags: ,
Engine Cutting Out!!!!! Smiffy42 First Generation Faults & Fixes 9 Jun 20th, 2010 01:14 PM
One D Cutting Out!! ONED First Generation MINI One D 19 Apr 29th, 2008 09:43 PM
urget please help! engine cutting out and lights on? eddycooper First Generation MINI Tuning 11 Nov 6th, 2007 05:12 PM
Engine cutting out sharky999 First Generation Faults & Fixes 0 Feb 16th, 2007 12:16 PM
H/K not cutting it msenkbeil First Generation Interior & Ice 1 Apr 22nd, 2003 07:32 AM
