Ticking Noise at Startup - MOD - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI One Diesel > First Generation MINI One D
First Generation MINI One D MINI One Diesel 2003 - 2006
Old Feb 18th, 2005, 10:35 PM
Local Time: 06:47 PM
I have a MOD with 6000 miles on the clock (Sep '04). I've just noticed some loud ticking noises at startup which disappear within about a mile of leaving home. The oil is very black and halway between the 2 dipstick marks. It sounds very much like hydraulic tappets that haven't adjusted.
Anyone else had the same issue in a MOD? I'm going to perform an oil top up to see if this makes a difference.
Old Feb 20th, 2005, 03:53 AM
ASTON's Avatar
A mini is a way of life.
Send a message via MSN to ASTON
Wales Male View ASTON's Pepper White & Black 2nd Gen MINI Cooper Diesel Profile View ASTON's Classified Ads
I would recommend an oil change i will be changing mine every 6000 without fail
Old Feb 20th, 2005, 11:19 AM
It pays to check the oil level regularly , I found that the diesel engine uses more than the petrol ( monitor the level each time you check it ) Put a pint in mine yest. Its a driving school car used mainly on urban routes.
Old Feb 21st, 2005, 07:19 AM
Yellow/Black OneD's Avatar
Clubman D
United Kingdom Male View Yellow/Black OneD's Mellow Yellow & Black 2nd Gen MINI Cooper Diesel Clubman Profile
Mine hardly uses any oil. Mine is always black, and any Diesel car's oil will be black, they run dirty, and thus shows that the oil is doing its job, although the colour is very scary!!
I haven't had the ticking, so can't help there, have you tried dealers?
Old Mar 2nd, 2005, 08:08 AM
I'm pretty certain it's either 'tappet' like noise or is the water pump expanding/contracting as the water starts to get warmer.....I think it started with the cold weather we've been having. Will be interesting to see if the warmer weather makes a difference (assuming we get some )
As an aside, cause there's no evidence of this noise after the first mile of travel, can diesels suffer from 'pinking' like petrol versions?
Old Mar 18th, 2005, 10:01 PM
By the way it seems that the valves on the diesel are adjusted manually - no hydraulics
Old Mar 19th, 2005, 09:09 AM
ASTON's Avatar
my has started to make a pinking sound . sounds like a bag of nails when i put my foot down. is this normal?
Old Mar 19th, 2005, 10:17 PM
ALD0's Avatar
Is that when First started up Aston?
Old Mar 20th, 2005, 07:15 AM
ASTON's Avatar
Wales
and when its hot .going on a mini run today so i will see if it gets worse after its been thrashed
Old Mar 21st, 2005, 11:18 AM
tribalmini's Avatar
Its a MINI thing.....
Scotland Female View tribalmini's Pepper White & Black 2nd Gen MINI Cooper S Profile
How did you get on yesterday? The noise still there??
Old Mar 21st, 2005, 11:26 AM
ASTON's Avatar
noise is still there,but its only when the engine is under load ie going up hill etc. i did have one problem on starting when warm.took several turns to starter it after a good run and sounded like a bag of nails.
Old Mar 21st, 2005, 11:50 AM
tribalmini's Avatar
Is it a trip to the dealer then Aston?
Old Mar 21st, 2005, 12:01 PM
ASTON's Avatar
its looking that way
Old Mar 21st, 2005, 06:52 PM
Have you tried a fill up with that special Shell Diesel? Supposedly contains agents that will clean your engine.
  #15 (permalink)
Old Mar 22nd, 2005, 01:25 PM
Clubman D
You have got the (nearly 2 years old now) hot start problem then Aston. They don't have a fix for this. Sound rough when they start don't they!! It will go away for the summer though Aston if that is any conciliation!
ticking noise ...is it tappetts???? aid First Generation MINI Cooper S 11 Aug 23rd, 2007 10:55 AM
Engine noise on startup KAS_MINI First Generation Faults & Fixes 16 Jan 22nd, 2007 11:11 AM
Ticking noise tom2005 First Generation Faults & Fixes 3 Aug 25th, 2006 08:07 PM
Ticking noise SiNNeD First Generation Faults & Fixes 7 Mar 14th, 2005 10:32 PM
Ticking noise PmP First Generation MINI Cooper S 8 Apr 3rd, 2004 01:14 AM
