| First Generation MINI One MINI One from 2001 - 2006 |
| Coilovers? i cant decide whether to go for eibach springs or spax RSX coilovers, i like the idea of great handling with coilovers but i also do quite a few miles on the ridiculously bumpy Cumbrian roads and dont want my car skipping all over the road. i dont want to go too low, only about 20mm. if i set the coilovers quite soft will this give me the compromise of handling and comfort i am looking for? |
| Day to day ride quality will of course be harder, but not massively so. You'll actually find that in a lot of conditions and on a lot of surfaces, the ride is "better" as it's more composed and less likely to "jump" around on bumps etc. It just feels more positive and a much sharper car, while not being excessively stiff (depending on which ones you get, and their setting, of course). At 20mm, you shouldn't scrape much, as this is much higher than even most lowering springs. What do you want to achieve from the coilovers? ![]() |
| i am planning on doing a few track days this year so the coilovers will be a better alternative to prings as i can adjust damping and ride height, the distance i drive will probably reduct this year too so i can set them up more for performance than comfort when that happens |
| springs. It was bottoming out, scraping. My car has wider archs and the wheels spaced so because the back end was bounching, the metal was cutting into the tyre, not a good combination. The spax i have now is on a firm setting, car doesnt bounce around any more and ive also managed to fit even wider tyres..225s...all good. |
| which coilovers should i get | alexvw | First Generation MINI Suspension | 0 | Oct 22nd, 2006 07:46 PM |
| Coilovers!!! | Faat | First Generation MINI Suspension | 5 | May 11th, 2004 01:00 PM |
| Coilovers ... help..... | KLZ | First Generation MINI Suspension | 2 | Dec 7th, 2003 03:48 AM |
| Which coilovers? | DinkaDonka | First Generation MINI Suspension | 9 | Dec 4th, 2003 01:00 AM |
| Coilovers? | gowest | MINI in Motorsport | 1 | Jun 7th, 2002 02:40 AM |
