In we go again - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI One > First Generation MINI One
Old Feb 20th, 2007, 07:28 PM
Jordan210's Avatar
Cyber Police
Send a message via MSN to Jordan210
Local Time: 06:32 PM
Suriname Male View Jordan210's Classified Ads
In we go again
Last time my car was in to the dealers fix the wind screen as it had to be refitted.
This time its going in for its gear box to be looked at. As some times when i put it in R it clunks and grinds the gears. It some times does it on other gears. It also some times has the tendency of slipping out of gear or not going in to gear. I mgith have a long wait on friday sitting in the dealers .
Does any one elces car do this ?
Jordan
MINI2's Resident Dyslexic
Old Feb 21st, 2007, 04:13 AM
West9's Avatar
Sam Sam the Ambulance man
Send a message via ICQ to West9 Send a message via AIM to West9 Send a message via MSN to West9
Local Time: 05:32 PM
United Kingdom Male View West9's Classified Ads
It seems to be a common thing.. I struggle to get mine into R, but to prevent damage to the clutch plate/Gearbox just look at it and you can tell when its in fully... I seriously doubt unless you're getting serious problems, its worth taking it in...
When I first got the ONE I was told try popping it back into a forward gear and then try again and engage Reverse...
Old Feb 21st, 2007, 02:11 PM
Jordan210's Avatar
Cyber Police
Well its warranty work so its all right and also it has a few things they need to change away.
Its so annoying changed up from 2nd to 3rd and it would not get in gear once it did it just grinds the gears
Old Feb 21st, 2007, 02:15 PM
marx87's Avatar
R56 MCS Works For Sale!
I did the same. i put it into first then into reverse with the clutch held in. Never grinds when i do that.
Old Feb 21st, 2007, 02:48 PM
devaisl's Avatar
Ireland Female View devaisl's Laser Blue & White 2nd Gen MINI Cooper S Profile
I had probs with reverse on my old R53 (I presume this is the model you're referring to!) and i found that if you hold the clutch down for a couple of seconds before engaging reverse the grinding did'nt happen....
Old Feb 22nd, 2007, 12:51 AM
West9's Avatar
Also make sure that your car is at a complete stop, and if that doesnt work, after trying the gears, try knocking it into Neutral, lift ya foot off the clutch and try again...
Old Feb 22nd, 2007, 12:59 AM
KillerByte's Avatar
Where does that road go?
Send a message via MSN to KillerByte
England Male View KillerByte's Hyper Blue & White 1st Gen MINI Cooper S Profile
Jordan's MINI is an 06, so yes it's an R53.
I used to have a similar problem on my 52 plate Cooper (R50 so Midland gearbox instead of Getrag). Reverse wouldn't engage properly resulting in crunching and frustration. I now tend to change to first gear and then reverse as this usually works first time in allowing reverse to fully engage (you feel should two clicks as the gear lever moves and locks into place). If this doesn't work, I find double de-clutching works.
Old Feb 22nd, 2007, 01:20 AM
Paul's Avatar
MINI2 No.1
England Male
It's an R50, a MINI One to be precise.
See: What are first generation, second generation, r53, r56 etc?
Our MINI One (company car, thank goodness), was like this, it always had a clunky/poor gear box.
It failed and left us at the roadside last year (lost drive in all directions) and we needed a new box. Should have seen it coming really.
Old Feb 22nd, 2007, 03:02 PM
KillerByte's Avatar
Oops. For some reason I'd associated the code R53 with the facelift instead of the Cooper S as it should be.
I know Jordan has a One.
Thanks for the clarification Paul.
Old Feb 22nd, 2007, 03:06 PM
Paul's Avatar
MINI2 No.1
England Male
A lot of people do get confuddled, which is why I try to avoid using the internal R codes where possible as it leads to a fair amount of confusion. Confusion of the worst kind, as people don't even realise they're confused! Especially with the way the S had it's own code in the 1st gen, but not 2nd.
Old Feb 22nd, 2007, 03:07 PM
hyperbluejames's Avatar
Ashes and dust Maximus!
Send a message via MSN to hyperbluejames
United Kingdom Male View hyperbluejames's Hyper Blue & Body Color 1st Gen MINI Cooper Profile
I find that when I slot the stick into gears sometimes it grinds and sometimes it doesn't. I'd really like to know how to do it so that it slips in smoothly. This is mostly from 1st to 2nd though; my MINI's an 06 Cooper. Never had a problem with any other gears crunching, reverse is always fine.
James
Old Feb 22nd, 2007, 03:12 PM
Paul's Avatar
MINI2 No.1
England Male
1-2 on the getrag's always seems to feel a little uncomfortable.
Old Feb 28th, 2007, 11:01 PM
i got told the same as west9 if it dont got in revise 1st time round try going in 1st then back to revirse as ur moving across the gearbox u then find where the problem lies it is when u first put it in or sometimes try bringing ur clutch out slowly but still puling back into revise works a treet for me no grinind noise any more
Old Mar 1st, 2007, 08:02 PM
Jordan210's Avatar
Cyber Police
Well after forgetting about my thread
The dealer could not se any thing wrong with it. To be honest i dout they Evan looked at it. If i try to skip gears like 2 - 4 th it wont go in properly it goes in a gap next to 4th and R Its going in again tomorrow
This time they might fix the Little ring round the handbrake whats been broken since i got the car and its all ready been in 2 times for it to be fixed and they still have not done it.
Btw is the car supose to pull to the left ? as its only just started to do it ? Should i get it re tracked ?
  #15 (permalink)
Old Mar 6th, 2007, 02:33 PM
Torquemada's Avatar
Clatu Verata Nictu!
England Male
, I seriously doubt that would be a design characteristic
Yep, get yer tracking and all that malarky checked out unless you like going in circles
Cheers,
T
Have you ever drunk baileys out of a shoe
Hunter S Thompson RIP
Tags: ,
