Changing Battery in the Key??? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI One > First Generation MINI One
Old Apr 20th, 2007, 02:54 PM
robbiebrown34's Avatar
RobbieBrown-com
Local Time: 03:15 PM
United Kingdom Male View robbiebrown34's Classified Ads
The battery is running low on my Mini key (2004 model) its becomming so bad that i have to stand next to the car to open it! I know how to open the key and change the battery. The question is: Will it still work after?
I have heard that you have to take it to the dealer to get the battery changed, because it "flashes" the key and it will no longer work on the car. Is this true? if so, how much will this cost?
I do have a spare key which works, but to be honest, its in perfect condition and i dont wanna use it unless i need to e.g. i lose the other key or something.
Old Apr 20th, 2007, 03:52 PM
faster,Tobias!'s Avatar
Fanatically Enthiusiastic
Local Time: 09:15 AM
Canada Male
In theory the key shouldn't need the battery replacing; they recharge while they are in the ignition, though if you don't drive all that often it could slowly 'bleed' flat. If that is the case, use it manually in the door lock and it will recharge when it is in the ignition. Or you may have a bad battery and it just won't hold a charge. Do note that they don't work seem to work that well in some areas, those with lots of radio waves and other electronic interference. And if you don't use the spare key occasionally, it too will eventually bleed out.
Old Apr 20th, 2007, 05:32 PM
JohnWB's Avatar
Local Time: 04:15 PM
United Kingdom Male View JohnWB's Laser Blue & Black 2nd Gen MINI Cooper S Profile
The 2004 MINI's did have a normal battery which needs changing. The R56 recharges the battery in the "key" when driving with it in the ignition slot.
Laser Blue / Black MCS - Arived March 07
Old Apr 20th, 2007, 05:55 PM
Restyle's Avatar
Damned
United Kingdom Male View Restyle's Hyper Blue & White 1st Gen MINI Cooper S Profile View Restyle's Classified Ads
Apparantly there have been several types of key battery fitted over the years.
To quote XRV848
The key was changed for the 2005 model year.
The 2004 owner's manual (USA) says:
"Replace (battery) if it is no longer possible to unlock the vehicle via the remote control...Only use a battery of the type specified on the battery, CR2032..."
The 2005 owner's manual says:
"In every master key there is an extended life battery that is charged automatically in the lock as you drive"
Old Apr 21st, 2007, 09:14 AM
MiniPetrolHead's Avatar
258.3bhp and 263.1Nm
Send a message via MSN to MiniPetrolHead Send a message via Skype™ to MiniPetrolHead
United Kingdom Male View MiniPetrolHead's Solid Black & Body Color 1st Gen MINI Cooper S Profile View MiniPetrolHead's Classified Ads
As to the radio waves comment, i have always wondered why i could lock and unlock the car from much further away at night, also different parts of town i can open it from further than others!
Old Jul 18th, 2011, 02:14 AM
dsakko's Avatar
Local Time: 01:45 AM
Australia Male View dsakko's Midnight Black & White 2nd Gen MINI Cooper S Profile View dsakko's Classified Ads
Time to re-open an old thread
I have an R56 MINI Cooper S race car. I've got the central locking working and the key will unlock / lock both doors but the remote buttons do absolutely nothing.
Yes, this should be the recharging type, and yes that means I shouldn't have to crack it open to change batteries, but as this one looks dead as a Dodo, does anyone know how to open the key? At least that way I can put a multimeter over it to see if the batt is dead or if there's other issues.
R56 MINI Cooper S JCW Challenge
Old Aug 31st, 2011, 02:18 PM
wright1D's Avatar
Well I have a 2003 Mini One D, it has a replacement battery, cos I had it confirmed by BMW, who also showed me how to get to the battery..
lever the cover off with a small screwdriver from the base of the key....
change the battery within 30 seconds... or you are in trouble...
put the cover back on and you are done...
Old Aug 31st, 2011, 09:19 PM
dsakko's Avatar
Yup. They changed the keys in 2007 I used to have a 2002 Cooper with the same style of key and yep easily changed.
Tags: , ,
Remote Key Battery MPJ General Discussion 23 Oct 17th, 2010 07:31 PM
Key Battery # Tom D General Discussion 24 Jan 19th, 2009 04:32 PM
How long is Remote Key battery life, please? dcfkan First Generation Faults & Fixes 43 Sep 3rd, 2005 08:48 AM
Problem: Changing Battery abstract First Generation Interior & Ice 2 Sep 1st, 2003 05:42 PM
