Bluefin- Help!!!!! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI One > First Generation MINI One
Old Jun 11th, 2007, 04:37 PM
minioneandrew's Avatar
Send a message via MSN to minioneandrew
Local Time: 09:13 AM
Scotland Male View minioneandrew's Dark Silver & White 1st Gen MINI Cooper S Profile View minioneandrew's Classified Ads
Bluefin- Help!!!!!
OK, staurday night my power steering pump completely failed, i phoned bmw 2day and got the car booked in for 2moro morning. Having bluefin installed i went out 2 revert back 2 standard. The bluefin unit failed, gave me an error code, and now the car wont start at all. I know there will people here who will say i voided my warranty by using bluefin... however im justa poor student, and now im very worried. Can anyone help? Many thanks
Andy
Old Jun 11th, 2007, 04:51 PM
deggles's Avatar
Local Time: 08:13 AM
England Male View deggles's Astro Black & Black 1st Gen MINI One Convertible Profile
I must admit I always take a deep breath whenever I swap the maps with my bluefin in case something like this happens! My first suggestion would be to postpone your appointment with the dealer and give Superchips a call on 01280 816781 or email bluefin@superchips.co.uk.
Hopefully it won't come to this but to put your mind at rest, Superchips' own warranty should cover any repairs required if BMW deem your warranty to have been voided:
In the unlikely event of bluefin being responsible for causing damage to your vehicle, Superchips will, under the terms and conditions of their warranty, repair your vehicle. The warranty is not intended to replace the existing manufacturer's warranty, but will supplement the cover to include the parts deemed to be excluded by the manufacturer. Contact Superchips for full terms and conditions.
Good luck mate, hope you get it sorted.
2005 MINI ONE CONVERTIBLE | [click for spec]
Old Jun 11th, 2007, 04:53 PM
spicy's Avatar
England Male
So was the Bluefin related to the Power steering failing?
Don't think I will be buying one of these afterall!
Old Jun 11th, 2007, 04:57 PM
The only thing with foning superchips is that i dont know if i have warranty with them?i never sent away the wee form that came with it? Anyways the power steering at been threatening to fail before i got bluefin, always on and off, and the day finally came on saturday. It seemed to cause electrical problems, when it failed the dials on the car went mad, and the lights flickered. So im thinking the pump has shorted out and damaged the ecu. I really am pretty worried at the moment.
Old Jun 11th, 2007, 05:10 PM
United Kingdom Female View I love MINI, Laura's Royal Grey & Silver 1st Gen MINI Cooper S Profile View I love MINI, Laura's Classified Ads
my power steering motorboard was working intermitantly and it completely failed. Sounds like whats happenedto yours. Nothing to do with the chip mate. I would ring Superchips about advise to get your motor back on line again and then just take it in. Loads of people don't bother to detune the car and get BMW to carry out work.
Old Jun 11th, 2007, 05:13 PM
deggles's Avatar
Ah I see, so sounds like the ECU was knackered by the power steering failure/electrical short, before you even tried to use the bluefin.
If that's the case then I'd let BMW sort it. Even if they detect the remap (unlikely) they would have to prove that was the cause of the damage, which is much less likely than the 'blue sparks flying' when the pump failed.
BTW if it does come down to it I think your Superchips warranty should still be valid if you have proof of purchase. The fact that your little postcard got 'lost in the post' shouldn't matter
Old Jun 11th, 2007, 05:15 PM
Thanks everyone for your speedy replys,ill email superchips anyway. my stomach jumped into my throat when it wouldnt start,im feeling a little better now. Thanks guys
Old Jun 11th, 2007, 05:18 PM
Hyper Active's Avatar
Local Time: 07:13 AM
England Male View Hyper Active's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile
A power steering pump failure will not have been caused by a Bluefin. This is just a straight forward BMW part failure, and as such BMW are obliged to fix it whether the car has been modified or not.
Old Jun 11th, 2007, 05:23 PM
Hes got to get it back on the road first though. That would be what I would be conserned about. Its not starting at the moment. Speak to them and ask their advise about getting it started again and then take it to BMW. It will be covered by the warrenty no problems.
Old Jun 11th, 2007, 05:42 PM
BMW offered 2 get a truck to pick it up under warranty if i felt it was 2 dangerous 2 drive without power steering. U think they wud be able 2 fix the ecu, if it arrived on a truck/?
Old Jun 11th, 2007, 06:11 PM
James's Avatar
England Male
Just a little side note....If BMW reflash your ECU with Bluefin on and it gets deleted, Superchips will reset your handset for free. My advice would be to let BMW fix it not mentioning the Buefin ( they will not notice it). Then send off the unit to superchips with the little form that came with it saying that your dealer reset your ECU and you would like the software updated. This is exactly what I did and it worked for me
Old Jun 11th, 2007, 06:41 PM
MiniPetrolHead's Avatar
258.3bhp and 263.1Nm
Send a message via MSN to MiniPetrolHead Send a message via Skype™ to MiniPetrolHead
United Kingdom Male View MiniPetrolHead's Solid Black & Body Color 1st Gen MINI Cooper S Profile View MiniPetrolHead's Classified Ads
Try this mate!!!!
Hi MiniOneAndrew,
I must admit that when i had a crash, my bluefin wouldnt come off, but did after about 4 attemts it finally came off!
This may not sort your problem but it is well worth ago!!!
Follow the stages:
1) put key in ignition (do not twist the key yet!!!)
2) press and hold the odometer reset buttom.
3) While holding the button down, turn the key to the 1st position, (the screen will then say "test" and then a number apears.
4) scroll through to test 19 and wait a moment.
5) after a short pause the screen will say "log i off" then "log i on" and then back to "log i off" again.
6) when "log i off" apears press the button again.
7) scroll through to test 21.
8) when you get to 21 it will say "reset" on the screen, press the odometer button again while the reset message is displayed.
9) the dash lights will go out and you will hear a buzzing sound. wait a few seconds and the dash lights will come back on.
10) now turn off the ignition, remove the key and wait a few seconds...
11) then try starting the car!
hope this helps
Alex
Old Jun 11th, 2007, 07:28 PM
cheers mate will print that off and give i a shot
Old Jun 13th, 2007, 02:43 PM
Update: Contacted superchips and they were very helpful and responded quickly, however after trying different things all day, i still couldnt get the car started. So last night the AA picked the car up and towed it to my dealership. Bmw are looking at it just now....
  #15 (permalink)
Old Jun 13th, 2007, 03:54 PM
MrLee2006's Avatar
England
This is the kind of thing that puts me off chipping my mini - hope you get it sorted ok.
Tags: , ,
Bluefin help MiniMadMarshy First Generation MINI Tuning 3 Sep 22nd, 2007 08:14 PM
Bluefin martinphipps First Generation Faults & Fixes 4 Sep 4th, 2007 11:28 AM
Bluefin, what can i say!!!!! Adam cook First Generation MINI One 91 Jun 17th, 2007 01:09 PM
help with bluefin please feybrand First Generation MINI Tuning 2 Jan 12th, 2007 03:06 PM
bluefin in the US? justinta First Generation MINI Tuning 1 Feb 16th, 2006 05:17 PM
