Airbag light with fault code - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI One > First Generation MINI One
Old Sep 14th, 2012, 09:38 AM
Local Time: 03:53 AM
Question Airbag light with fault code
Hi to all at mini2.com, I'm a newbie here having just bought my 1st mini one, R50 2002. I'm having airbag light problems, I had to replace the airbag ecu as it was faulty, so managed to get a used one from ebay. I am now getting "11 battery, positive terminal isolation 1". Indicating the the battery safety link is faulty. Yet as far as I can make out the mini one does not have a battery safety link, (it looks like this only applies to the cooper models with a battery in the boot)
can someone shed some light on what might need doing to enable me to extinguish the airbag light.
Might be worth mentioning I have also installed a used leather interior too but there are no other faults showing on the reader.
Some help would really be appreciated.
Mike
Old Sep 14th, 2012, 10:56 AM
Duno if it works like this but have you got a used one from a mini one.
Old Sep 14th, 2012, 10:32 PM
mab01uk's Avatar
Local Time: 04:53 AM
As said by James B above, maybe the replacement airbag ecu was from a Cooper S (battery in boot) and has been programmed to look for the battery isolation link which is not fitted on your One, thereby registering a fault code?
Old Sep 16th, 2012, 09:43 AM
Skitos's Avatar
Having looked on ebay they all state make sure part number matches, worth checking you new and old ECU have the same part number?
Old Oct 24th, 2012, 04:26 PM
Mike
Just had this problem with my 2002 MCS.
Fault code reset and recurred 20 miles later,eventually traced to water in the battery well in the boot,and damp obviously around terminals.
Now in the process of drying everything out and finding out where the water is coming from,then having the light reset again.
Old Mar 28th, 2013, 04:42 PM
Well..........I think the battery well has well and truly dried out by now.Just
come back from independant garage,still showing fault code 11,bugger !
Anyone any ideas ?
There is a little connector at the side of the battery link in the battery-
well,could this be unhappy at being submerged in water ? All replies
gratefully recieved,Ta !
Old Mar 31st, 2013, 05:50 PM
CCroker's Avatar
Local Time: 10:53 PM
United States Male
Water is never good on electrical connections, clean and reconnect. Seats replaced, recheck you'r connections. Sometimes if not push in right codes will pop.
Charlie Croker ,BRG 03 Cooper S, SCCA Solo, PDX, Time Trials, RoadRally, and Stella, 011 Oxford Grn Countryman S
