I'm going to take a Mini for a test drive tonight. It's 2002 with 71k.
Is there anything I should be looking for? It has the auto transmission. The dealer is only asking 7900 for it.
Check the cvt auto transmission works very carefully as they are expensive to fix if faulty, a transmission oil/fluid change is a good idea and a new battery if it is still the original 2002 fitted, as the auto computer is very sensitive to low volts. I would advise taking some kind of warranty out if possible if the potential cvt trans repair/replacement prices are likely to worry you.
I bet it has the same low voltage issues as my BMW. I'm currently driving a 325ci with the steptronic, The battery was going on it and cause all sorts of transmissions issues. Put in a new battery and the issues went away.
However if you looking at an 2002 R53 Cooper S then All Cooper S, from start of production (2002), had a traditional automatic transmission, not a CVT. The later 2007 onwards Mk2 MINI autos are also conventional type auto transmission.
