Yellow engine light OBD recomendation - MINI Cooper Forum
Go Back   MINI Cooper Forum > Model Specific MINI Forums > MINI One > First Generation MINI One
R56 Overload indicator light, no water in engine issues LadyUK Second Generation Faults & Fixes 1 Nov 13th, 2013 05:26 PM
Check Engine Light fortunot General Discussion 4 May 27th, 2013 02:05 AM
Oil light and engine management light k12yla Second Generation Faults & Fixes 1 Mar 7th, 2013 06:52 PM
Engine light, reduced power & louder exhaust TomNeal Second Generation Faults & Fixes 4 Nov 28th, 2012 09:03 PM
Engine light when sat in traffic scottp7 Second Generation MINI Cooper S 2 Feb 22nd, 2012 03:04 PM
Old Dec 27th, 2013, 01:16 PM
Local Time: 02:27 AM
United-Kingdom Yellow engine light OBD recomendation
Hi,
My 2003 one petrol, yellow engine light came on today. I've read that this maybe due to some emission fault or even a loose petrol (gas) cap.
To be sure I want to get a cheap ODB fault code reader, but it's a mine field out there when trying to choose one. And not owning one before didn't want to make nubbie mistake.
I found this:
Unable to post URL's yet - Doh!
on eaby odb reader with this title
"Universal Car Fault Code Reader Engine Scanner Diagnostic Tester Tool OBD2 D900" 9.95
Nice little cheap unit and I have a complete list of codes including the mini specific codes on laptop ready.
Would anyone who has a cheap odb2 reader advise if a bog standard code reader like the above is going to give me the information for my mini? Failing that perhaps recommend something cheap to do the job?
thanks
Old Dec 27th, 2013, 06:40 PM
Local Time: 03:27 AM
Hi ya
Looks ok for a basic one will do what you need.
The Other options there may be a member locally to you that my help out.
Failing that are you a member of a break down service such as AA, RAC
The eml light could be on for a few reasons. it's a good chance it's a lamba sensor but you need the code from the DME. Before rushing in spending you hard earned
Old Dec 28th, 2013, 08:34 AM
Quote: Originally Posted by marque (original)
Hi ya
Great, I ordered the reader so will see what codes we get when it arrives. BTW I forgot to mention the car drives perfectly so apart from the light there appears to be no issue, so hoping this will be a small cheap issue to correct, fingers crossed. Going to google "lamba sensor" now...
thanks
Old Dec 28th, 2013, 09:39 PM
Hi ya
RealOEM.com * BMW R50 One 1.6i Exhaust manifold with catalyst
If your car has been using a lot of fuel or running rough it's a good chance it may be the sensor.
But don't go rushing in to things before you get the code. You could do the basics first check your spark plugs, air filter also pull of you no 4 spark plug lead of the coil pack make shore it's not corroded.
It's free and easy to check
Where in the country are you
Hope it helps
Old Dec 29th, 2013, 11:15 AM
Hi ya
Hope it helps
Thanks for your help!
I'm near Lutterworth, south of Leicester.
The engine is running fine and no signs of any problems... Mileage is high 136k so if on original sensors probably needs changing as I read BMW recommend 100k interval.
Looking at that diagram the exhaust outlet is nearest to the bulkhead, so inlet must be at front.
Do I access the lambda sensors from under the car or is it possible between the bulkhead and the manifold from above? For some reason I though the exhaust came out from the front of the car.
Also is it worth removing the sensors and cleaning them as well as checking / cleaning connections?
There are post cat Lambda sensors on ebay for 30 (new), so I guess from the description they are not the same sensors, before and after cat, can you confirm?
Can't do anything till ODB reader turns up, not marked as despatched yet due to holidays so probably looking towards middle to end of next week.
Old Jan 6th, 2014, 12:21 PM
Reader turned up today and I get two codes:
P2270
O2 sensor signal stuck lean bank 1 sensor 2
P0420
Catalyst System Efficiency Below Threshold (Bank 1)
Car dives fine, no mods.
Does P2270 Does bank 1 sensor 2 refer to the 2nd O2 sensor after the cat?
Perhaps I need a new cat converter?
Anyway, I have reset the codes and will wait to see what errors come back.
Any advise?
Tags: , , , , ,
» Recent Threads
Help, is this a cooper S??
Yesterday 09:29 PM
by markdm
Last post by markdm
Today 01:29 AM
6 Replies, 109 Views
Cooper S Engine Rebuild
Yesterday 07:44 AM
Last post by marque
Yesterday 11:49 PM
1 Replies, 105 Views
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by Grumpee1
Yesterday 11:29 PM
18 Replies, 1,066 Views
O2 sensors in exhaust
Yesterday 06:03 PM
Last post by marque
Yesterday 11:24 PM
1 Replies, 64 Views
Mini Cooper S R56 Timing Chain Tensioner
Feb 24th, 2013 11:53 AM
Last post by MCMULC
Yesterday 09:08 PM
9 Replies, 6,667 Views
Just bought mini what extras do I need to tell insurance about
Mar 19th, 2014 03:51 PM
Last post by JohnnyC
Yesterday 07:43 PM
7 Replies, 599 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by mab01uk
Yesterday 07:10 PM
7 Replies, 426 Views
Constant problems with my R50. Should I keep it or replace? Need advice please
Apr 3rd, 2014 03:52 PM
by kteara
Yesterday 07:03 PM
14 Replies, 890 Views
Spare wheel 55 plate cooper
Yesterday 01:32 PM
by ajn
Yesterday 07:00 PM
2 Replies, 84 Views
Need new rims, any ideas
Apr 8th, 2014 10:14 PM
Last post by CoolioMcPimp
Yesterday 06:44 PM
3 Replies, 308 Views
Cup holder inserts
Yesterday 06:23 PM
Last post by Captain5691
Yesterday 06:23 PM
0 Replies, 57 Views
Electrical Issues with 2003 Cooper base
Mar 10th, 2014 07:09 PM
Last post by The Nun
Yesterday 05:29 PM
3 Replies, 447 Views
Strange Braking Noise
Jan 28th, 2014 08:27 PM
Yesterday 05:22 PM
8 Replies, 961 Views
Mini One D - engine out, how difficult?
Jan 8th, 2014 09:36 PM
Last post by scott132
Yesterday 03:19 PM
3 Replies, 697 Views
R52 A pillar interior trim removal
Yesterday 08:11 AM
Last post by clockworks
Yesterday 02:57 PM
2 Replies, 75 Views
Boot switch not working
Mar 8th, 2014 10:23 AM
Last post by burnstar
Yesterday 11:04 AM
4 Replies, 402 Views
Attention to Detail (UK) - spot the difference!
Yesterday 09:43 AM
by sailesh
Yesterday 10:47 AM
1 Replies, 125 Views
Changing Oil????
Mar 3rd, 2014 12:32 PM
Last post by habi222
Yesterday 09:31 AM
8 Replies, 742 Views
Mini Cooper S Rebuild
Yesterday 07:49 AM
Last post by budgie2014
Yesterday 07:49 AM
0 Replies, 87 Views
Engine mounts
Dec 22nd, 2013 07:47 PM
Last post by johnnycatbiscuit
Yesterday 04:21 AM
3 Replies, 801 Views
Wheel & Tire Center
