Cylinder misfire problem - only when cold. - MINI Cooper Forum
post #1 of 2 (permalink) Old Jan 9th, 2014, 12:04 AM Thread Starter
Local Time: 12:43 AM
Netherlands
I have an annoying problem that my garage cannot sort out. About a mile after cold starting, the engine warning light flashes then stays on and the engine appears to be running on three cylinders. I attach an analyser and it tells me there is a cylinder 1 misfire. I stop the car, restart and the fault disappears. I have replaced plugs, leads and coil. Any ideas? Thanks!
mrbasstrombone is offline
post #2 of 2 (permalink) Old Jan 9th, 2014, 04:52 PM
United Kingdom Male View Blusox's Laser Blue & Body Color 1st Gen MINI Cooper S Profile View Blusox's Classified Ads
have you tried a compression test? If the ECU noticed something wrong with compression in a cylinder it will cut fueling to it in order to prevent damage to the engine and exhaust by un-burnt petrol. I had a broken valve spring that did the same error for me, I got a misfire if I accelerated hard.
Blusox is offline
Tags: , ,
Intermittent sound problem with IPOD and AUX inputs dsmith Second Generation Interior & Ice 3 Jan 22nd, 2014 09:30 AM
Problem starting in the cold weather Misty2013 MINI Clubman 1 Dec 31st, 2013 09:22 PM
Central locking/ car starting problem in cold/ wet weather C & C mini First Generation Faults & Fixes 3 Nov 4th, 2012 05:11 PM
rattle. revs up and down, cold start, backfire, jerking misterdarkness Second Generation Faults & Fixes 1 Oct 20th, 2012 01:02 AM
Mini jcw 09 cylinder 2 misfire with super knocks yianni General Discussion 1 Aug 16th, 2012 07:13 PM
