my 2004 mini wont start - MINI Cooper Forum
post #1 of 5 (permalink) Old Jun 14th, 2014, 04:44 PM Thread Starter
Local Time: 11:44 AM
It has been dragging when I go to start it for a couple weeks. I went out to leave yesterday now it won't start at all but when I turn the key on everything comes on I hear the relays click and all it just won't start.... Please help! Any ideas on what could be wrong? Right now were thinking it could be the starter or corrosion around the pos that goes to the starter.
minicooperbabe1049 is offline
post #2 of 5 (permalink) Old Jun 14th, 2014, 06:24 PM
Local Time: 04:44 PM
Quoted: 53 Post(s)
You need to check the first thing which is the battery, a poor or low charged battery will have sufficient power to light up the instruments and click a few relays but wont have enough left to turn the engine over as that is the one thing that takes the most power.
So check the battery first, is it holding sufficient charge and is it charging effectively and the terminals are clean and tight before you go any further?
If the battery is still the original its probably had it by now.
The Nun is offline
post #3 of 5 (permalink) Old Jun 14th, 2014, 08:10 PM
heathwebbo's Avatar
Local Time: 03:44 PM
As nun says sounds like the battery, try jump starting it off another car to see if it starts easy
heathwebbo is offline
post #4 of 5 (permalink) Old Jun 14th, 2014, 09:19 PM Thread Starter
Well we just had the battery and the starter checked come to find out its the starter
post #5 of 5 (permalink) Old Sep 30th, 2014, 05:55 AM
Particular power supply
You'll want to look at first thing which is the particular power supply, an unhealthy or small priced power supply should have adequate power to illuminate the particular equipment as well as click several relays yet won't have sufficient remaining to turn the particular powerplant above as which is the the one thing of which will take probably the most electric power.
And so look at the particular power supply first, could it be holding adequate fee and it is this asking effectively as well as the terminals are generally thoroughly clean as well as restricted prior to going any more?
In the event the power supply is the original it is possibly received this can't.
thomasusa80 is offline
New 14 plate Mini Cooper SD Coupe Nightmare Kickboxkel Welcome New Members 7 Apr 4th, 2015 12:33 PM
Mini HQ - Terrible ethics for the customer. jobforacowgirl Dealership Feedback 11 May 22nd, 2014 05:36 AM
Brands Hatch Mini Festival 22/23 June 2013 mab01uk Mini Events 20 Jun 23rd, 2013 10:03 PM
Brooklands Mini Day Sunday, March 24, 2013 mab01uk Mini Events 11 Apr 5th, 2013 06:11 PM
Mini Australia service chilld Dealership Feedback 4 Sep 4th, 2012 05:29 AM
