MCS exaust for my ONE - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI One > First Generation MINI One
Old Jul 16th, 2005, 04:19 PM
DeK's Avatar
DeK
Dominique et Karine
Send a message via MSN to DeK
Local Time: 10:08 PM
France
Thumbs up MCS exaust for my ONE
Hello,
I assembled an exhaust from MCS ,bought of occasion at a super price. I thus decided after having seen that dimensions and the supports were the same ones to assemble the whole. 2 working hours, the result is marvellous.
Fixings are those of the S, I have just to remove the spare wheel. The noise is very sympathetic !!! I also specify that I did not make this modification with an aim of gaining performances, but only for the look!
I have changed 3 parts into plastic of the shield AR to perfect the whole. If you want infos, you can see on my Internet site and to leave me an e-mail, I answer you with photograph...
Before:
At work:
After:
(escuse for my english)
You think what of it?
Name:	fixation coté conducteur.jpg
ID:	93219   Click image for larger version
Name:	fixation coté passager.jpg
ID:	93220   Click image for larger version
Name:	pièce montée.jpg
ID:	93221   Click image for larger version
our 7 is: COOPER S R56 10/2009, Laser/Blue White, 175PS, side light marker, Eibach, exaust JCW 211
my page & picture albums: http://www.motorlegend.com/membre/dek.html
Old Jul 16th, 2005, 05:34 PM
Rayman's Avatar
"Buying and selling"
Send a message via MSN to Rayman
Local Time: 09:08 PM
United Kingdom View Rayman's Indi Blue & White 1st Gen MINI Cooper Profile
Nice one looks great, a perfect fit! When you say the noise is sympathetic, do you mean it is quiet?
2001 cooper (sold)
1995 Supra RZ-S TT auto in white.
Old Jul 16th, 2005, 09:37 PM
Widgey's Avatar
United Kingdom Male View Widgey's Chili Red & Body Color 1st Gen MINI One Profile
That looks
Good work
Old Jul 17th, 2005, 07:31 AM
DeK's Avatar
DeK
Dominique et Karine
France
détail from parts
thank you for all the private messages
I answer on the forum because it is simpler, and that will still use for others...
The part of fixings are 182 014 937 97 + 182 014 937 98 (left and right, in black at the picture from the first post), with dimensions driver there are two holes on standby, those holes on standby (with a layer of cement) under the carpet of the trunk, you will be able to put two screws at this place and to screw fixing.
On the other photographs one can see that I made small do-it-yourself with parts BMW. indeed the hull of the ONE/COOPER is not exactly the same one, therefore it was necessary to adapt a fixing, so that the marmitte is not in the vacuum leaves number: 182 075 214 27 + 182 011 760 13
For the back plastic from MCS: parts 511 268 002 34 + 511 214 790 94 + 511 214 790 93. You must thus change the two half-with dimensions one because the height of spolier back is not the same one.
A friend with me with fact the modification on a cooper and it does not have there a concern private individual on the by-shocks AR... It is necessary to be meticulous person and to adjust the parts, it well is all, do not listen to people who did not do this work...
Escuse me of the translation, I made use of google, the barrier of the technical language is at all obvious, just like to explain in detail...
ID:	93308   Click image for larger version
Name:	soutien à démonter.jpg
ID:	93309   Click image for larger version
Name:	manque mièce.jpg
ID:	93310   Click image for larger version
ID:	93311   Click image for larger version
Old Jul 17th, 2005, 11:40 AM
JpMcC's Avatar
JP :-)
Ireland Male View JpMcC's Chili Red & White 2nd Gen MINI Cooper Profile View JpMcC's Classified Ads
looks great, I done this mod a few months back, I was also extremely pleased with the results, it looks and sounds fantastic
Old Jul 18th, 2005, 06:10 AM
si_power's Avatar
Local Time: 04:08 AM
Thailand
Dek,
Regarding performance, did it cause any problems? how badlywas the performance after placing the MCS exhaust on since ONE's and MCS's exhaust are of different sizes. Did you do any engine mod to your ONE?
same questions to you, JPSmini
Thanks for the help since i'm trying to fix a MCS exhaust on my ONE as well.
MINI in Thailand
Old Jul 18th, 2005, 07:02 AM
DeK's Avatar
DeK
Dominique et Karine
France
no problem there is the place below and the spare wheel remains with the garage, it is all... If not of adjustments engine. I have a friend who with assembled a "supersprint" and it is the same model for all the range ONE/COOPER other COOPERS, then why not the silencer of the MCS ??
The sound approaches the MCS (as we have a MCS, this is easy to compare !!!) and in the chapter performances the MINIS go better, it seems liberty !!! (traduction... ) it is also very sensitive when air-conditioning is on the way !!!
Old Jul 18th, 2005, 08:25 PM
the_red_skin's Avatar
Mini One rACe Schnitzer
Send a message via MSN to the_red_skin
Belgium
Belgium
Mdr... comme on se retrouve.
J'étais avec Dju pour monter la ligne JCW, ben je dois te dire que c'était pas une chose facile. Au contraire... Surtout que nous, on avait pas de fosse. Joli boulot en tous cas.
Old Jul 19th, 2005, 08:48 AM
si_power's Avatar
Thailand
what do u mean by liberty? and what do you mean by being sensitive when air-con is switched on?
ps. sorry for asking too many questions
thanks for the help
MINI in Thailand
Old Jul 19th, 2005, 07:23 PM
DeK's Avatar
DeK
Dominique et Karine
France
the car is not "choked" with this modification compared to front (traduction is not evident ) this is very sensible !!
With air-conditioning there is always a small pert of power on the ONE, since it is better (when the rp/m is not hight 2/3000 rp/m)
the modification is very positive
it is clear ???
Old Jul 20th, 2005, 02:15 AM
si_power's Avatar
Thailand
thanks for the reply dek
so the exhaust comes out of both two exhaust pipes or just one? i'm planning to close one pipe so that it'll be the same as the standards exhaust.
MINI in Thailand
Old Jul 21st, 2005, 01:26 PM
DeK's Avatar
DeK
Dominique et Karine
France
I do not know if one can close an exit, I left both opened two. I am not an enough technician to answer
Old Sep 14th, 2005, 07:31 PM
Phoenix's Avatar
Cooper Reborn
Send a message via MSN to Phoenix Send a message via Yahoo to Phoenix
Local Time: 08:08 PM
United Kingdom Male View Phoenix's Liquid Yellow & Black 1st Gen MINI Cooper Profile View Phoenix's Classified Ads
Has anyone else done this?
Would like some info please.
Regards
Old Sep 28th, 2005, 07:25 PM
My Pocket Rocket's Avatar
Local Time: 04:08 PM
Hi DeK,
Great job you did there. What is the part number for this?
I want to use that to fit 02 exhaust on my 04 MCS.
Cheers!
  #15 (permalink)
Old Sep 29th, 2005, 02:51 PM
DeK's Avatar
DeK
Dominique et Karine
France
it is a part which I modified with two part of Bmw-minis. One needed that I fix the marmittes of both with dimensions, below the MINI ONE (Cooper also) it is not similar only the S (battery box...)
I do not include/understand too much, you want to assemble othe MCS exaust 2002 on a MCS 2004, if it is an S, that will be similar below, not?
Replacement Exaust 02 Mini One pholcroft First Generation MINI One 6 Aug 2nd, 2006 09:34 PM
What's the best exaust? lex76 First Generation MINI Tuning 2 May 27th, 2004 07:10 AM
Question about exaust.... klorte First Generation MINI Tuning 5 Jul 30th, 2003 01:12 PM
Cooper'S' Centre Exaust for Cooper supercuper First Generation MINI Exterior 0 Aug 16th, 2002 02:09 PM
