30mm lowering question - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 30th, 2006, 01:35 PM
Richard22b's Avatar
MINI Mad
Send a message via MSN to Richard22b
Local Time: 02:56 PM
United Kingdom Male View Richard22b's Classified Ads
Yellow Cooper 30mm lowering question
HI everyone
now this has probably been asked a few times but what the hell I'll ask it all again.
I am planning on lowering my car by 30mm on springs.
Will I need to change any other parts apart from the springs for it to be OK.
I believe the standard shocks will allow this drop.
Advice as always very welcome.
PS. the car is booked in tomorrow for the work to be done.
Old May 30th, 2006, 01:38 PM
St00ge's Avatar
8/10 on the Stoogometer
Send a message via MSN to St00ge
Local Time: 11:56 PM
Australia Male
you don't have to do anything else
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
danb's Avatar
Local Time: 01:56 PM
United Kingdom Male View danb's Astro Black & Body Color 2nd Gen MINI Cooper S Profile View danb's Classified Ads
I fitted a set of eibachs this weekend, and yes you only need the springs themselves.
After doing the job, I would suggest - if you are at all mechanically/technically minded - to do the job yourself. It took just under an hour and a half to fit all four, and the only specialist tool you need is spring compressors (they could concievably be done without, but safter with some). You will of course need to have your tracking done after, I paid £35 for 4 wheel-alignment (most small garages only do 2 wheel)
Old May 30th, 2006, 01:43 PM
St00ge's Avatar
Australia Male
you might want to have a look at this as well....
http://www.northamericanmotoring.com...ad.php?t=69497
Old May 30th, 2006, 01:45 PM
Richard22b's Avatar
MINI Mad
I would try it myself but don't have the tools to do it.
Its costing me about £130 to get it done.
Old May 30th, 2006, 01:54 PM
danb's Avatar
thats a fortune, I had quotes of around £70
You don't need many tools, just what the standard DIYer has in the shed
Old May 30th, 2006, 01:57 PM
Richard22b's Avatar
MINI Mad
ok. its starting to sound like this should be my evening job tonight.
So what will i require to complete the task.
Plus any visuals on how to do it
Old May 30th, 2006, 02:04 PM
danb's Avatar
I used this thread as a guide - although I found some of the socket sizes are wrong.
Basically you will need a socket set ranging from 13mm - 20mm, and preferably a breaker bar (long bar for sockets) to undo the tight ones.
An impact wrench is handy, but definately not a necessity
I used spring compressors while taking the old springs off - most tool hire shops have these (I paid £6 for Friday-Tuesday). If you are careful enough you won't need them, but I would suggest using them to be on the safe side. They are not needed to get the eibachs on if you have someone helping you.
Thats it I think
Oh and of course a jack
edit: and you need a 5mm allen key
Old May 30th, 2006, 02:13 PM
Richard22b's Avatar
MINI Mad
Well all looks good.
none of the pics on the instructions show on my machine.
do they on yours?
How important is a torque wrench.
thanks for all your info.
Old May 30th, 2006, 02:21 PM
danb's Avatar
No, the pics don't work anymore unfortunately - I found everything was pretty self explanatory once we got the wheels off though
A torque wrench is good if you want to be precise when tightening the bolts back up, but as I didn't have the figures to hand I didn't bother using one, just went by what felt right.
Old May 30th, 2006, 02:24 PM
Richard22b's Avatar
MINI Mad
Yellow Cooper
OK sounds good.
If i don't have a spring compressor am I going to kill myself as odds are i will be doing this on my own.
Old May 30th, 2006, 02:27 PM
St00ge's Avatar
Australia Male
just hire one....
Old May 30th, 2006, 02:53 PM
RCMini's Avatar
RCMini
Italy Male View RCMini's Classified Ads
I just lowered my mini two weeks ago using the proceedures that danb stated along with one from randy http://store.webbmotorsports.com/for...topic.php?t=13 I suggest to have two people when you do it. It makes it alot easier and faster.
Old May 30th, 2006, 03:02 PM
Richard22b's Avatar
MINI Mad
Just checked and can buy a spring compressor from halfords for £9.99 which seems a better price than £130 for the work to be done.
Think my haynes manual also has some bits on how to do it with pics (I hope)
  #15 (permalink)
Old May 30th, 2006, 03:04 PM
RCMini's Avatar
RCMini
I also had a bently service manual when changing out the springs. The only thing is that if you use a manual it is a little to indepth and really makes the job harder than it needs to be. If you have a manual use it for reference but find a couple good threads and just follow them.
Advice on lowering, 20mm or 30mm? R99 First Generation MINI Suspension 14 Aug 31st, 2007 09:27 AM
lowering 30mm whats the rub? alski First Generation MINI Suspension 6 Jun 12th, 2007 06:47 PM
30mm lowering on s suspension? mutilator First Generation MINI Suspension 31 Apr 3rd, 2005 05:31 AM
Is Lowering 30mm on 15's ok??? Adeline First Generation MINI Exterior 8 Jul 27th, 2004 07:46 PM
Question on Lowering Minty First Generation MINI Suspension 16 Nov 13th, 2003 08:24 AM
