suspension and drive problem - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 28th, 2006, 08:45 AM
Local Time: 03:31 PM
United Kingdom View Maui's Classified Ads
Hi
I am not sure where to put this, so I am going to put it in here.
I have my 25k service in two weeks and my mini one is beginning to feel not as good as it did when I got it 10k miles ago. The steering isn't as tight as it was and the suspension not as stiff.
The tracking has gone on it a bit, so I will need to get this sorted and this will hopefully improve things a lot.
My car is still under warranty, as I only brought it 6 months ago from dealer.
What I was wandering was, what I can ask for for free when it gets serviced that may sort out some of the problems above. i.e what is covered by warranty that might solve this or make it better
failing that what cheapish ideas does anyone have for improving these problems.
thanks in advance for any advise
maui
Old Sep 28th, 2006, 12:09 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Local Time: 04:31 PM
Quote: Originally Posted by Maui (original)
Hi
maui
You'll probably find it's just general wear and tear on the suspension components. I've heard a couple of people complain about the ride being not as tight as it once was. The only thread I've seen that solved the issue was to replace the various bushes in the suspension system.
It was acceptable in the 80's
Old Sep 28th, 2006, 12:51 PM
Richard Crofts's Avatar
THE STICK
Change to better poly bushes (can be expensive)
get the swivels checked for play and fit new ones or pack with grease (if this is possible on a BMW MINI?)
Fit a strut brace...both upper and lower.
New anti roll bars on front and back (stiffer ones?)
Better shocks and lower springs or a coil over kit
These will all help but it depends on warrantee needs and your wallet size
This is the most unprofessional bit of site management I have seen since I was banned from a certain other site...at least they had the excuse that they were enthusiasts who had strong views and not professionals paid to keep thier cool!
Old Sep 28th, 2006, 01:17 PM
What will all of these things cost and which is likely to give the best results for the money
Old Oct 4th, 2006, 10:53 AM
THE STICK
Go to lohen.co.uk and check out the full suspension p[ackages they do. They also sell all those items seperatley too. They are reasonable on price but there are others cheaper if you search hard and know the exact items you want.
R
Old Oct 9th, 2006, 05:15 PM
GTT 280's Avatar
The Power Cube
United Kingdom View GTT 280's Classified Ads
DIY Loose steering / suspension
Hi there. I too have the sensation of loose steering and suspension, compared to when it was new. I have coil-over shocks, 18" rims and front camber plates fitted. Also have AP racing BigBrakeKit (BBK).
I've had BMW look at it, and Lohen, both say that there is nothing mechanically wrong with the setup, both parties applied some lube to the bushes etc. So i conclude that it must be the rubber bushes wearing out.
I think that if you drive hard and have a suspension setup like mine where the ride can be quite harsh, then the rubber bushes must be wearing out by now. (or what ever OEM bushes are made out of).
I am considering powerflex bushes for all suspension and steering components. Not sure how much that would cost though, and wonder if that would truley fix the problem?
Anyone?
Cheers,
CSW.
Suspension problem? yjo First Generation MINI One 10 Aug 8th, 2008 06:51 PM
Suspension Problem meenieme First Generation MINI Suspension 0 Jun 16th, 2007 02:09 AM
KW V2 coilover suspension problem ERdoc First Generation MINI Suspension 18 Mar 9th, 2005 02:22 PM
suspension problem?? HELP! miniman marshall General Discussion 8 Jan 4th, 2005 08:57 AM
Suspension top mount problem! DinkaDonka First Generation Faults & Fixes 2 Oct 4th, 2003 04:30 PM
