Camber setup - the perfect figures !! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 5th, 2006, 05:43 PM
GTT 280's Avatar
The Power Cube
Local Time: 09:13 AM
United Kingdom View GTT 280's Classified Ads
DIY Camber setup - the perfect figures !!
To anybody with tuning knowledge....
I have fitted Eibach Rear Control Arms & Eibach Adjustable Front Top Mounts and would really like to know what camber setting are the best for fast road.
I am thinking of a figure between 0 and 0.5 degrees
Old Oct 5th, 2006, 08:50 PM
Trailer Trash
Local Time: 03:13 AM
United States Male View k-huevo's Solid Black & White 1st Gen MINI Cooper S Profile
Negative 0.5 degrees camber is ineffectual; stock camber for the front is about -0.5 degrees and stock rear is -1.5 degrees. So if you want less understeer and more front end stick then set the fronts to -2 degrees camber and keep in the neighborhood of -1.5 in the rear. For some front stick but still retain less scary stock characteristics; bring the fronts in and add more camber in the rear relative to the front. Experiment until you find the setting you feel comfortable with. Don’t forget to re-align toe.
Old Oct 5th, 2006, 11:06 PM
Ryephile's Avatar
Deals Gap Junkie
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
Local Time: 04:13 AM
United States View Ryephile's Indi Blue & White 1st Gen MINI Cooper S Profile
Ditto k-huevo's wisdom.
I run -1.3 front and -1.6 rear as an example.
Old Oct 6th, 2006, 09:42 AM
GTT 280's Avatar
The Power Cube
I actually found that the stock camber settings (with the right tyres) have been the best ride so far.
I am looking for 0.5 on the front and 1.5 on the rear, but of course will play around with options to compare on that day.
Cheers.
Old Oct 6th, 2006, 12:20 PM
MINI 2 Sponsor GT Tuning
United Kingdom View roland2003's Classified Ads
A lot of people think they need more neg camber on the front than they do. Stock front neg is -0.5 degrees. I have tried -1.6 degrees on mine and was slower round the track.,so I'm now back at stock -0.5 deg. Couple that to longer braking distances, less grip under acceleration & very uneven tyre wear (bald on the inside edge) ,and the stock setting looks even more tempting.
Other things that effect optimum camber are:-
-Tyre aspect ratio & wall stiffness. (Very low profile tyres require less neg. camber)
-Suspension stiffness ,the stiffer it is the less neg. camber required.- TBF mine is very stiff!
-The circuit your on. Fast sweepers are better with less neg camber. Too much makes the steering too sensitive/nervous, as does too much tow out.
-Driving style;a 'late agressive turn in' requires more camber than an 'early gentle turn in'-. The latter suits my style better.
For road use stock setting is IMHO definatley best.
Best Regards Roland GT Tuning
Old Oct 7th, 2006, 10:14 AM
robbo mcs's Avatar
Track Addict
Local Time: 07:13 PM
Australia View robbo mcs's British Racing Green & White 1st Gen MINI Cooper S Profile
Hi,
The point Roland makes about camber is a good one
Speaking purely from a track race / rally car perspective, choosing the right amount of negative camber is a trade off. Going to a higher degree of negative camber improves turn in and cornerning, but as Roland points out is is detrimental to straight line power down and acceleration, due to the decreased tyre contact patch.
There is no one "Magic" right setting. As Roland points out it depends on other factors such as suspension and ride height, driving style, preferred handling characteristics, etc etc
I have done a lot of testing, and I know what works well for me, in my car. That doesn't necessarily translate to someone elses car
Robbo
Mods: Hartge kit, CAI, oil cooler, headers, cat & exhaust, bilstein coilovers, adjustable bars & camber plates, quaife diff, roll cage, seats, harnesses
GO MADDIE and SPARKY!
Old Oct 7th, 2006, 05:26 PM
Trailer Trash
Robbo, please share your range of camber settings.
Old Oct 8th, 2006, 09:26 AM
robbo mcs's Avatar
Track Addict
Hi,
A good point to start for a circuit / tarmac rally car is :
Front : max caster / -2 camber / 1mm toe out
Rear : -1.5 camber / 1mm toe in
These are not the settings I am running, but are a good starting point for the average car set up.
As I said before, it is different for everyone depending on your car set-up (roll cage stiffness, shocks, springs, ride height etc etc).
With the set-up I currently have the turn in is amazing, mid corner speed is good, but you are sacrificing straight line speed and braking
Robbo
Old Oct 9th, 2006, 03:05 PM
TimCrighton's Avatar
Beer Society President...
Send a message via MSN to TimCrighton
United Kingdom Male View TimCrighton's Pure Silver & Black 1st Gen MINI Cooper Profile View TimCrighton's Classified Ads
We set ours up according to the customers driving experience and style, however generally our cars are set up in the region of 0.5 to 1 degree neg on the front, with approx 1 to 2 degrees on the rear (we adjust rear toe more than we adjust the rear camber). It also ultimately depends on peoples requirements, one should and needs to consider that any movement away from stock can cause unnecessary tyre wear without much gain.
Track Day Instruction - New MINI specialist!
Old Oct 9th, 2006, 03:22 PM
GTT 280's Avatar
The Power Cube
Thumbs up The end.
Quote: Originally Posted by TimCrighton (original)
....one should and needs to consider that any movement away from stock can cause unnecessary tyre wear without much gain.
And that is basically the crunch. Stock setting unless you are a British Touring Car driver !!!
Old Nov 10th, 2006, 03:01 AM
MiniFr34k's Avatar
fr34king n00b!
Local Time: 06:13 PM
Australia Male View MiniFr34k's Classified Ads
dumb q: but whats a good setting for street then? just lowered my car recently, and rear camber is shocking. im still learning this, but no idea whats the ideal settings for street camber.
thanks in advance.
Old Nov 10th, 2006, 03:49 AM
obehave's Avatar
Mini Mod
Quote: Originally Posted by robbo mcs (original)
Hi,
Robbo
Doesn't the front also get a bit twitchy at high speeds with front toe out compared to toe in?
It works great for auto-x but I've noticed at higher speeds you give up a bit of stability.
I'm running 1/16th which is about 1.5mm toe out.
Like you said, it's a starting point. Just wanted to point out the other side of the toe issue.
Old Nov 10th, 2006, 05:39 PM
robbo mcs's Avatar
Track Addict
Hi,
You are quite right. Front toe out makes the car turn in very well, but it can make it "twitchy" and over responsive. Also, due to the way the front suspension works, the car tends to toe out naturally under heavy braking, so it can get even more twitchy under heavy braking and trail braking
A little toe out is good for autocross, or tight circuits, but neutral is probably better for general road driving or high speed circuits.
Robbo
Old Nov 10th, 2006, 05:41 PM
robbo mcs's Avatar
Track Addict
thanks in advance.
Hi,
The figures I gave for the rear (-1.5 camber and 1mm toe in) are actually very conservative settings, and would be fine for street driving. Most people I know who are racing / rallying are actually much more aggressive eg -3 to -3.5 camber and 2-4mm toe in.
cheers
Robbo
  #15 (permalink)
Old Nov 11th, 2006, 09:47 PM
Local Time: 01:13 AM
United States Male View olddad's Chili Red & White 1st Gen MINI Cooper S Profile
Robbo, just a coincidence your settings are almost exactly the ones I used as a starting point on my '66 Cooper S race car in the '70s. Started there and adjusted for track conditions.
Cooper S Red/White/White, Air, Computer, Cloth, DSC, Cold Weather. August build.
camber kits Fisher First Generation MINI Suspension 0 Nov 16th, 2005 06:54 PM
Perfect Camber GTT 280 First Generation MINI Suspension 15 Jun 14th, 2005 09:22 AM
Best camber plates? Ben83 First Generation MINI Suspension 1 Mar 22nd, 2005 06:30 AM
Adjustable Camber ? coops41 First Generation MINI Tuning 9 Oct 16th, 2002 02:38 PM
