| First Generation MINI Suspension MINI Suspension from 2001 - 2006 |
| Think you'll get a lot of people singing the praises of the GTT one on here. It is quite pricey though, but I can't comment on value for money as I don't have one I have a JCW one that was fitted form new so can't really comment on how much of a difference it made. I have since fitted the OMP lower one and could definitely feel the difference. I think most people would agree with the above and tell you to get at least a top and bottom brace, big improvement. There is a lot of debate on here about the value of the rear brace (behind the seats) as it doesn't actually attach directly to the strut towers. Personally would leave that one to last. |
| Aid, if you lie down at the side of your car and look directly behind the front wheels you'll see a silver coloured hex bolt angled forwards / downwards at 45 degrees. You simply take these out offer up the brace and ( using two new bolts from BMW ) tighten in place. You do not need to jack car up or remove wheels. It's a 5 min job honestly. The GTT mid lower brace is just as easy with four bolts ans is situated about 2 feet further back. I'd start with the OMP lower and then add as you can afford. If you do a search you'll see lots of threads / pics / how to's on these braces. 57 Plate R56 PW/B MCS |
| The GTT upper has been raved about on this forum from day one. I personally, at the time, couldn't believe that it could make that much difference, but the high praise converted me. I met up with Tigger a couple of weeks ago, he also has one and sung it's praises. So much so that I ordered one from Roland the other day. |
| ...and you'll see there is only one option that works. GTT upper front (and lowers too if you like). The rear brace is not a strut brace, so don't waste your money. (that's why GTT don't make one, there is no point) Cheers, K. ![]() Too many mods to list, PM me if the cat needs killing... |
| OMP front strut brace | willc38 | First Generation MINI Suspension | 11 | Aug 20th, 2007 09:49 AM |
| OMP Strut Brace on Cooper S | Aberdeen Al | First Generation MINI Suspension | 3 | Jun 26th, 2006 12:17 PM |
| OMP Rear strut brace fitting | Pepper'D | First Generation MINI Suspension | 0 | Feb 5th, 2005 11:46 PM |
| Mini One with OMP Strut brace? | mgemie | First Generation MINI Suspension | 7 | Oct 6th, 2004 11:46 PM |
