Rattle from front suspension - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 5th, 2009, 05:47 PM
Local Time: 05:32 PM
Italy
So, lately I've been hearing a distinct rattle from the left side of the front suspension, and I have no idea what it might be. Or, better, I have an idea but I dunno if that's possible. I was thinking maybe the wishbone bushing was shot? But I feel no difference in the car's handling and I know I should feel it if it were the bushing, right?
Also, since I had to change the clutch this summer while I was away, I was thinking if maybe the mechanic who did the job didn't tighten everything properly and something has come loose? The noise started not long after the job was done, too bad I wasn't there anymore otherwise I would have brought it back to make him check it...
Old Sep 5th, 2009, 07:27 PM
PK5
Local Time: 04:32 PM
the bushing wont make it handle any different but you may hear a constant knocking when you turn the corner
Old Sep 6th, 2009, 07:27 AM
Italy
Thanks, I thought the bushing would make it less stable on fast turns, and pull slightly on the side of the shot bushing...anyway, I feel it mostly when going over bumps, reading some similar topics on NAM I got the impression that it might be or the cv joint, or the ball joint, or, simply, the front sway bar endlinks that need to be tightened. I'll be checking these three things and see if I can get a better idea of what it is, but if anyone has suggestions, feel free to write them down!
Old Sep 8th, 2009, 09:03 AM
Italy
Does anyone know how to check if the cv joint and/or the ball joint are shot? I took a look yesterday and they seem fine, the dust boot of the cv joint seems whole, but I'd like to "test" them and see if the noise comes from any of these two...or eventually from the tie rod, so if anyone knows how to check that one too, that'd be great.
Old Sep 8th, 2009, 10:54 AM
MINI One Seven
United Kingdom Male View M.O.S's Pepper White & Body Color 1st Gen MINI One Profile
A bush will make a difference - much more play so you'll definitely notice this at speed - the parts in question will move more than they did previously. In order to hear the knocking you'd have to actually get the car moving fast enough to make the noise, but slow enough to allow you to hear it. The best bet would be to let a mechanic have a look... I'd replace both sides - chances are if one has gone the other will soon...
The Original MINI One Seven
Yorkshire MINI Register - PM for details
Old Sep 8th, 2009, 11:51 AM
Italy
Yeah I suspected that a bushing would make a difference, but the car handles perfectly fine so I'd rule that out. I will let a mech have a look for sure, it was more for personal curiosity to see if I could find out what it is while I wait for my mech to be available (he will be next week). As for changing both sides, of course I'll do that but thanks for the suggestion anyway
Tags: , ,
Suspension rattle, banging noise ? Socalcoopster First Generation Faults & Fixes 5 Feb 28th, 2012 10:57 PM
rattle, vibrating noise at front of sunroof Randy Blackmon First Generation Faults & Fixes 2 Dec 17th, 2007 07:33 AM
Cooper S rattle in the front ParkLane First Generation MINI Cooper S 0 May 6th, 2007 09:08 PM
Low speed rattle from front right?? rntheald First Generation Faults & Fixes 15 Jun 13th, 2006 03:49 PM
Suspension rattle- how to convince dealer its there? ezrally First Generation Faults & Fixes 6 Jul 29th, 2004 11:28 PM
