| First Generation MINI Suspension MINI Suspension from 2001 - 2006 |
| Had front Bushes changed Has the front lower wishbone and lower engine mount bushes changed by a local garage today - and apart from the torque handling reduced what other benefits should I see... and how important is it that I get the wheel balanced/tracking aand alignment checked again? Will this also make a difference to the handling? I have also had the gearbox oil changed to redline - let's see how this is - I haven't had a chance to open my MCS' lungs yet - but will do on the way home from work... |
| ok so drove it a bit last night and all seems a bit better - ride is steadier and more stable on the road which is good. but the turn in is not that greatly improved - could this be due to something else not being right? Bearings? |
| yes - changed to Superflex bushes... Running stock/standard suspension...actually I should test the suspension to see if it is ok... But I have noticed when trying to park in a car park the other day, at full lock to the left, a knocking/clicking noise which seemed like it was coming from the left wheel area... I just wonder if the bearings now need to be checked/replaced... |
| Tags: bushes, gearbox oil, oil, redline |
| Price & advice on Front Suspension Bushes for R53 COOPER S | mini33 | First Generation MINI Suspension | 15 | Nov 5th, 2010 05:51 PM |
| front lower arm mount bushes | simonbuysellit | First Generation MINI Suspension | 16 | Nov 5th, 2010 01:36 PM |
| Front wishbone bushes | Wez007 | First Generation MINI Suspension | 1 | Jun 22nd, 2009 07:54 PM |
| Super Flex Front Control Arm Bushes Fitting | roland2003 | First Generation MINI Suspension | 5 | Sep 13th, 2007 03:38 PM |
