lowering a 8 year old mini?? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 24th, 2010, 07:07 PM
mini doller$'s Avatar
Local Time: 09:06 AM
United Kingdom Male View mini doller$'s Classified Ads
hello to all the mini2 people out there!!
i want to get rid of the horred gap in the arch i have got 18" wheels on and want to keep them realy ive seen the eibach 30mm lowering springs but is it safe to be lowering it when its 8 years old will the shocks take the strain???
wheel spec
18" bk 399
215 35 18zr w84
will there be any rub on the archs and when turning on full lock
need as much info as pos because i dont no anything about this
ps i know theres coilovers but dont have that sort of money
thanx lee!
Old Feb 24th, 2010, 11:04 PM
MINI One Seven
United Kingdom Male View M.O.S's Pepper White & Body Color 1st Gen MINI One Profile
You've been told why you don't want to put lowering springs on an 8 year old car.
Yes its doable. Would I do it? No. Simple reason - your dampers will be getting on, and whacking some stiffer springs with less compression space is going to ask a hell of a lot of them.. The only way to do it with springs would be to uprate the dampers at the same time (something such as Koni FSD), but it won't be a cheap way.
It comes to something when a vendor of lowering components has said they won't sell you them due to safety reasons... Surely thats enough to tell you that springs won't be a suitable option. Especially as its an every day car with big wheels.
Do it once, do it right and safely. Don't risk the safety of yourself and other road users.
The Original MINI One Seven
Yorkshire MINI Register - PM for details
Old Feb 25th, 2010, 04:30 PM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
^^ got it covered basically. Your shocks will probably be not at their best by then so chucking on some springs isnt the best idea...
if your dampers are on their way out why not try some koni dampers and springs - but the better option would be coils...
you mention money - possibly best to save to cover having to change out the dampers, should that be needed... 18s, springs and old dampers isnt going to be great - will look good mind but not drive well. plus your dampers would then wear even faster with springs on...
possibly best to save to change the suspension properly - springs arent the solution at the moment...
would need to know the wheel offset to see if rubbing may be an issue - i never had rubbing with ET52 and 30mm springs...
Running 211whp
Old Feb 25th, 2010, 05:44 PM
hey m.o.s yes ive been told but i just wanted to know if any one on hear has done this. safty does come 1st gess i need to start saving
Old Mar 28th, 2010, 05:30 PM
Local Time: 06:06 AM
id do struts too. it depends also how handy you are. if you are comfortable with doing the work yourself and dont mind having to take the suspension out when/if the oem struts go bad, then go for it. otherwise, id save up for struts and springs or coilovers to do it once.
MINI year on year sales up 18.5% Paul General Discussion 7 Mar 14th, 2008 11:47 PM
Lowering Mini GP? zstkng First Generation MINI Cooper S 4 Apr 23rd, 2006 10:46 PM
lowering mini? happihana First Generation MINI Exterior 0 Sep 14th, 2005 05:23 AM
Lowering a mini blackflamer General Discussion 4 Jul 22nd, 2003 09:59 PM
