Rear Suspension - Car Not Level - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 22nd, 2011, 03:23 PM
Cooling Expert
Local Time: 04:32 PM
Wales
Wales Rear Suspension - Car Not Level
Ok, here comes my problem.
I have a 2005 Mini 1 with standard suspension,which is not level on the rear, bought the car 3 months ago and it didn't seem as bad as it is now.
Jack the Car up & it's fine, both wheels drop the same amount.
Springs checked out - all OK, no cracks or breaks.
Dampers have no leakage and feel the same either side, so I doubt the internal seals are passing on 1 side.
I've read about the car having to be bolted up with a set weight in the car and was thnking if the previous owner did some work and didn't bolt it up correctly.
Anyone had any similar problems?
Kidology
Old May 26th, 2011, 05:24 PM
Mike Edwards's Avatar
England View Mike Edwards's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View Mike Edwards's Classified Ads
Extra things to check:
Are the trailing arms bent?
Do the front mounts for the trailing arms look to have been disturbed?
Are the camber adjusters (if fitted) set the same side to side?
Tags: , ,
rear suspension spannerking Second Generation Faults & Fixes 2 Mar 6th, 2008 04:42 PM
rear clear lights and high level light and fog jcw 60 First Generation MINI Exterior 3 Jun 13th, 2007 07:56 PM
How much should i pay for some clear rear lights with high level brake light .Boyracer. First Generation MINI Exterior 3 Jul 24th, 2005 09:46 AM
Smoked light kit - side repeaters, high level brake and rear lights!!! matt1584 First Generation MINI Exterior 0 Jun 12th, 2005 05:25 PM
