Easy, Take it straight back, let them know the jobs not up to scratch, dont mess with it yourself. And if you feel too nervous to drive get them to collect it.
Does it also happen when you're turning with full-lock on? I've had a similar problem in the past, albeit not on a MINI but after the same sort of work, and it was a loose bolt somewhere! Tightened it up, problem solved.
Hello, can you elaborate a bit more on this suggestion?
You mean that it may be that the anti roll bar is not bolted in or loose?
I have the exact same issue, but it also sounds whenever there are lateral forces (ie. if I do sudden and short S turns left and right and the car tries to roll sideways) hard to do on an S model with Sports suspension I know!
Also when I take a speed bump diagonally so the car rolls a bit...
