Sports suspension plus - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 29th, 2013, 09:03 PM
Online
Local Time: 07:12 PM
I've tried searching, nothing conclusive.
What *exactly* is 'sports suspension plus' on the gen1 ?
Lot's of rumours about thicker anti-roll bars, springs, dampers.
Anyone know for sure?
Old Jan 29th, 2013, 09:24 PM
Caveman's Avatar
Local Time: 08:12 PM
Sport Suspension has 22.5mm front and 16mm rear sway bars.
Sport Suspension Plus has 24mm front and 17mm rear sway bars.
Old Jan 29th, 2013, 10:15 PM
Online
Thank you, very precise there
Are those the only differences?
Same springs & dampers?
Old Jan 29th, 2013, 10:37 PM
Caveman's Avatar
The RealOEM part numbers for front struts and rear shocks are dependent on suspension type so I assume they are "valved' differently.
I think spring rates are dependent on vehicle weight.
Old Jan 30th, 2013, 10:38 PM
Online
Excellent, thank you.
I was thinking of going for an alternate brand to OEM as I have very little faith in BMW suspension componenets.
Don't want to go down the 'modification' route for insurance reasons.
But saw that Bilstein B4's are 'OE spec', but am now confused as there's clearly more than one type or 'OE spec'!!!!
Old Feb 8th, 2013, 07:06 PM
beken's Avatar
Send a message via ICQ to beken Send a message via MSN to beken Send a message via Yahoo to beken Send a message via Skype™ to beken
Local Time: 11:12 AM
Canada Male View beken's Black-Eye Purple & Body Color 1st Gen MINI Cooper S Profile
I think the springs and shock valving between sports suspension and SS+ are the same. The only difference were the anti-roll bars. The JCW suspension had shock valving matched to the weight (options) of the car and different springs which also lowered the ride height a bit.
05MCS BEP Alta 22mm rear anti-swaybar, Madness CAI, Alta 15%, NGK BRK7EIX, M7 Strut Tower Reinforcement plates, BSH Lower Engine Mount
