suspension issues - MINI Cooper Forum
First Generation MINI Suspension
post #1 of 4 (permalink) Old May 9th, 2014, 03:36 PM Thread Starter
Local Time: 05:19 PM
suspension issues
Good morning mini2 members,
I've got an 03 s. I've replaced the control arm bushings and ball joints. The problem that persists is a very sloppy, almost like driving on water feeling. The nose feels like it's taking a dive and when I go around turns, for freeway ramps for example, the front rolls a bit and the traction control kicks in and basically tells you to slow down. The strut tower mounts are shot and I will be replacing those as well, regardless of if they are the culprit. I hope you guys can shed some light so this mini doesn't turn into a money pit.
Again, I've replaced bushings and ball joints with brand new ones. I want to get this sloppy feeling taken care of before I drop more cash on tires and an alignment.. Make the mini what it's famous for because right now its a chore.
adamMiniS is offline
post #2 of 4 (permalink) Old May 10th, 2014, 03:07 AM Thread Starter
Anyone help narrow this down?
post #3 of 4 (permalink) Old May 10th, 2014, 05:29 AM
Local Time: 03:19 AM
Quoted: 178 Post(s)
Australia Male
Garage
Strut tower mounts, shocks, coil springs assemblies, this will cause you to wander, bounce, dive, porpoise around if they are worn or damaged. Affect your braking and stability on the road.
Have a look at this youtube video to check if the tower itself is also damaged, youtube.com/watch?v=XtG9HooBG6I
Milpol is offline
post #4 of 4 (permalink) Old Sep 18th, 2014, 07:35 PM
Local Time: 06:19 PM
Quoted: 13 Post(s)
It sounds like a front shock absorber failure, maybe just one, but change them in pairs. if you're doing the top mounts the shock is coming off anyway so check them before stripping perhaps?
ExclusiveWorkshops is offline
PANORAMIC SUN ROOF ISSUES -I'm in talks with Mini Head Office UK PLEASE READ/CONTACT LadyUK General Discussion 63 Oct 8th, 2015 05:56 PM
Mini Cooper S engine issues TrevS First Generation MINI Cooper S 4 May 4th, 2014 11:29 AM
Mini Cooper s engine issues jakvette General Discussion 0 Feb 12th, 2014 06:49 PM
Panoramic Sunroofs Issues, Queries, Problems etc LadyUK Second Generation MINI Cooper S 0 Nov 15th, 2013 03:43 PM
About Front wheel suspension NiuNiu First Generation MINI Suspension 3 Aug 21st, 2012 08:45 PM
