| First Generation MINI Suspension MINI Suspension from 2001 - 2006 |
| Minty, i had Eibachs installed, 30mm drop and did not have the tracking checked at all, I checked my tyres for wear every weekend and can confirm that no undue wear occurred on any tyre. The springs made no difference to the handling either, but, if you want peace of mind you know what to do. Bonnie Scotland |
| KDS is a full alignment check carried out by the dealer, and it normally takes 2 hours to complete...so can be quite expensive. then if it needs adjusting it can be a further 2 hours. Check with your service dept for the price per hour. Last edited by Minty; Oct 7th, 2003 at 07:43 AM. |
| Hi there Bonnie Scotland By dropping the car by this much, what wheels are you useing, ie size, 17s / 18s and have you come across problems with sleeping police bumps in the road. You might think that this is a stupid question, and sorry for taking this off topic, but i had exactly the same problem happen to me when i lowered my VW Beetle ![]() Cheers Roman |
| I am running 18 inch wheels with 215 x 35 tyres, i got a little rub on the rears when coming across sharp dips in the road, i removed the little spats on the rears and it reduced it a lot, but not totally. I have recently had a rear sway bar fitted and am just waiting to try it to see if the stiffer bar will cure it. Bonnie scotland |
| My Eibachs have lowered the car 20mm all round and yes I do have a slight problem with the sleeping policemen (front vallance touches slightly if driven to fast) I run the 7.5j 18" Hartge Classics with Pirelli P7000 215/35/18 and like Bonnie Scotland have not had to have the tracking altered. Sorry off topic here but BS what swaybar have you fitted I have been after the Madness but no luck? Rasp Last edited by rasp; Nov 3rd, 2003 at 09:05 PM. |
| No difference? This surprises me. I installed the H-Sports on my S about two weeks ago. I can honestly say that their was almost a quantuum leap in the handling ability of my car. I already have the Madness rear sway and had dropped from 17's to 16" wheels and running Bridgestone Pole Positions for tires. Bonnie Scotland, I'm not disputing your claim. Just really surprised that you found little difference in the handling. Missing my buddies Dan, Ed, and Diane but glad I have three angel buddies , And on a quest to Right Secco's Wrongs Last edited by Cape Cod MINI; Nov 3rd, 2003 at 10:15 PM. |
| Oops , don't know what i was thinking there, in the words of many a public figure "I was misquoted", only thing here of course is that i typed it, doh!! I can only think i was trying to say that no undue tyre wear occured, ok, hole deep enough!Anyway, i am happy to report that yes, the handling was improved significantly (i remember posting about it when it was done), most noticeable on roundabouts Thanks CCM, without your diligence i might have misinformed the public and in this day and age of being politically correct we can't have that can we Bonnie Scotland |
| lowering my works and wheels question | Tommy R | First Generation Works | 0 | Jan 29th, 2007 09:21 PM |
| help with lowering???? | The_length | First Generation MINI Suspension | 1 | Oct 7th, 2006 02:51 PM |
| 30mm lowering question | Richard22b | First Generation MINI Suspension | 30 | May 31st, 2006 08:44 PM |
| Lowering | miniwurks | First Generation MINI Suspension | 7 | May 29th, 2006 09:39 PM |
| Lowering ??? | b2uke | First Generation MINI Exterior | 18 | Aug 19th, 2004 10:25 AM |
