A How to fit a JCW strut brace with an Alta CAI - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 25th, 2005, 05:24 PM
Pobsey's Avatar
The de Chromed MINI
Send a message via MSN to Pobsey Send a message via Yahoo to Pobsey
Local Time: 03:14 AM
United Kingdom Male View Pobsey's Dark Silver & White 1st Gen MINI Cooper S Profile View Pobsey's Classified Ads
Hello, I have just fitted a JCW strut brace on my car with an Alta CAI, thought I would do a quick how to...
Make sure the car is parked on a level surface,
1, Take a 13mm socket and remove the 6 nuts that hold the Strut to the car body (dont jack the car up with these bolts undone ) Place the strut brace in postion and mark on the strut brace the area that needs to be removed.
See photos below
2, Remove CAI heat shield and cut the area marked out (I used a Jr hacksaw and a file)
Once you have done this replace the heat shield and retry the brace (with the rubber seal on the top of the heat shield)
3, Install both the right and left hand brackets, just pinch the nuts up, then attach the central section to the right hand bracket, then adjust the length of the central section by undoing the 17mm nut and turn central section to undo the thread, once the central section is the correct length bolt it to the left hand bracket.
4, Tighten up the 6 nuts (3 on each side) to 81Nm and tighten the 2 allen bolts along with the 2 nuts that adjust the length central section.
Hope this helps any questions just ask
Oh one more thing If you mess it up its not my fault so you do this at your own risk!
Old Apr 26th, 2005, 09:55 PM
RedUn's Avatar
MUGEN POWER
Japan Male
I did the same but used a dremel to get a nice smooth finish to the cut out but i'm like that
I also cut the seal and replaced it just after the brace to just to make sure there are no squeaks as well..........other than that spot on
Old Aug 6th, 2005, 05:43 AM
SharkReef's Avatar
www.thesharkreef.net
Local Time: 08:14 PM
Anyone know if this is the right torque setting for just a regular install on the JCW Strut Bar? I read on Motoring file.com that it should be at 34 Nm. Any help suggestion would be great!!!
Take it easy,
Eric
Old Aug 6th, 2005, 01:07 PM
RedUn's Avatar
MUGEN POWER
Japan Male
just tighten them up so they aint comin off
don't over tighten them tho or else theres a good chance they will shear off
Old Aug 6th, 2005, 09:36 PM
SharkReef's Avatar
Thanks RedUn!!!
I installed it today in about 25 minutes or so. Most of that time was spent looking for the right tools. I had to go out and buy a 30 piece hex key set just to get the ONE that I needed. I haven't got to really go out and drive it yet but here are some pics.
ID:	95992   Click image for larger version
ID:	95993   Click image for larger version
ID:	95994   Click image for larger version
ID:	95995   Click image for larger version
Take it easy,
Eric
Old Aug 8th, 2005, 11:27 PM
MiniMelSF's Avatar
EverythingButThe Mini
For what it's worth, I tightened mine (on my newly-installed JCW strut brace) to 34 NM. According to Bentley's manual, the top strut mount bolts are torqued to 34 NM, and I figured that the new bolts would not be any different, but maybe this was wrong. They sure felt snug enough to me and none stripped. Anyone know for sure?
ID:	96471   Click image for larger version
ID:	96473   Click image for larger version
2005 MCSC JCW CAI, JCW exhaust, Webb-installed Alta 15% pulley, JCW strut brace, Whalen...and still modding!
Old Aug 8th, 2005, 11:55 PM
Rakey's Avatar
Total MINI dot com!!
Local Time: 04:14 AM
United Kingdom Male View Rakey's Classified Ads
I would recommend that they are set with a torque wrench, rather than the as tight as you can method
Also the nuts I believe are a locking nut I believe from what I have read on this forum, so if you take them off, you should replace them with new ones to ensure they don't work undone
Old Aug 9th, 2005, 08:28 PM
RedUn's Avatar
MUGEN POWER
Japan Male
Thanks RedUn!!!
looks fantastic
Old Aug 9th, 2005, 08:34 PM
RedUn's Avatar
MUGEN POWER
Japan Male
ever checked how tight yer wheel bolts are after they have been set to the correct torque?? trust me I prefer the as tight as you can method
i've never torqued anything in my life and there have been no problems so far
also yes they are locking nuts and should be replaced a but a drop of threadlock will keep them from going anywhere
Old Aug 9th, 2005, 11:13 PM
Rakey's Avatar
nope, because if I did then they wouldn't be torque'd anymore
fitted by dealer for that very reason
Old Aug 10th, 2005, 04:56 PM
RedUn's Avatar
MUGEN POWER
Japan Male
u aint ever took a wheel off a car?
no self trust
Old Aug 10th, 2005, 05:25 PM
Rakey's Avatar
no self trust
not off this one, why should I, paid me money I get the service I deserve
Old Aug 10th, 2005, 10:03 PM
RedUn's Avatar
MUGEN POWER
Japan Male
the cleaning of the alloys thats why
we don't like em dirty on the inside do we
Old Aug 10th, 2005, 10:17 PM
Rakey's Avatar
enoough room between spokes on mine to get the rear clean but then not much point cleaning anthracite
  #15 (permalink)
Old Aug 10th, 2005, 10:54 PM
RedUn's Avatar
MUGEN POWER
Japan Male
excuses excuses, you just don't want to get yer hands dirty
Alta cold air intake + JCW strut brace? minicore First Generation MINI Tuning 6 Jun 27th, 2006 06:46 PM
GTT CAI - strut brace fit? MickCooperS First Generation MINI Tuning 4 Jun 2nd, 2006 09:39 AM
?:CAI bonnet seal /w strut brace Rich'sFroggy First Generation MINI Tuning 3 Oct 2nd, 2005 06:18 AM
Does a JCW Strut Brace fit on a Cooper (non-S)? rkw First Generation MINI Suspension 2 Sep 19th, 2005 10:05 AM
Alta CAI with a Strut Brace??? Help! whokilledkaji First Generation MINI Tuning 1 Aug 15th, 2005 06:21 PM
