| | LinkBack (6) | Thread Tools | Rate Thread |
| MTH or disconnect the battery like Buttons said. But MTH is the best option by far. The disconnecting the battery can sometimes give a small improvement as the ECU will relearn its setup. Expect it not to want to go when you first pull away... thats normally. Just boot it and it will all be ok. |
| yes it can: In order to reset the ecu follow the procedure below 1) With the key in the off position press and hold the speedo reset button, turn the key to position one and the screen will say test and a number. 2) Go through the list by pressing the reset button upto test 19 and then wait. 3) The display should then say"log i-off" then "log i-on" over and over again....when "log i- off" appears again press the reset button ....and now you are in the system software. 4) Scroll upto 21.0 Software reset. When reset appears press the button again and you will get a beep and you're speedo needle may vibrate a little (this is normal). 5) Turn ignition off then back on to position 2 for 10 secs then start your car and hey presto its done. |
| Errr, ok.... **Wonders what went wrong last time ** I stand by MTH as a user since it makes a big difference. |
| personally i didn't have a problem but a mate did - he took his car to the redline & it went into emergency mode at high speed. luckily there was no more than a scare & the car was reset with a battery disconnect but it makes you realise you're messing with £15k of car with no more backup than an email address & no legal redress - plus technically no insurance unless you declare it in advance. you pays your money, you takes your choice - it makes the car feel great but for me its not worth the risk financially if it goes wrong |
| Think that was recognised as throttle Position sensor wasnt it?? Its personal choice at the end of the day. I look at it like there's more risk getting out the shower |
| Hi Ya, I went to Superchips the other day in Northampton, and they have just finished their BLUEFIN chipping system for the new MINI. It's a hand held device, bout the size of a mobile phone, you can chip the car through the diagnostic port. Handy thing is you can change it back at any time. I had my cooper S done and I noticed the difference straight away. ( go to mybluefin ) |
| i'm not talking about chipping or remapping the ECU which is a permanent change to the factory software, such as MTH, Powechips etc, i'm talking about RESETTING the ECU - ie clearing its adaptive memory so that i can 're-educate' it with a harder driving style. d'oh, i give up......... |
| I noticed on mine that after a battery disconnect it would drive like a bag of spuds for a day or two, then it would sort itself out. I think it depends on how you drive it to begin with, if you hot foot around the performance will be great but fuel economy will be poop Give it a try, you got nothing to lose really |
| If it's anyting like the motronic system on VWs, the ECU learns fastest in the 1st 30 minutes or so of running after a reset, then moves to a gradual optimisation setting. In the VW, you can make the most of these 1st few minutes through full throttle acceleration in higher gears from lowish rpm, plus gentle cruising at low speeds in medium gears to let it figure out when the throttle is closed and when it's just opening. |
| i reset it yesterday & booted it all the way home (25 miles). it feels a bit more responsive this morning so i'm going to continue to drive hard see how the fuel consumption goes. one thing when i got home last night, after turning the car off the cooling fan came on really hard for about 5 minutes. mind you, i had been doing 110 10 minutes earlier *ahem* |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-tuning/100632-ecu-reset-how-much-difference-does-make.html | ||||
| AnandTech - 2009 Mini with Carbon build-up | Post #0 | Refback | Apr 5th, 2009 01:18 PM | |
| AnandTech - 2009 Mini with Carbon build-up | Post #0 | Refback | Mar 19th, 2009 11:48 PM | |
| Bekijk onderwerp - Hoe kan je de computer resetten? | This thread | Refback | Jan 24th, 2009 09:53 AM | |
| MINI COOPER :: North American Motoring - Resetting the ECU | Post #0 | Refback | Jan 19th, 2009 09:30 PM | |
| MINI COOPER :: North American Motoring - Low power-off the line | Post #0 | Refback | Dec 10th, 2008 07:09 PM | |
| MINI COOPER :: North American Motoring - Low power-off the line | Post #0 | Refback | Nov 16th, 2008 02:59 PM | |
| ... | andjeoruzo | General Discussion | 0 | Nov 22nd, 2006 02:28 AM |
| ECU reset | Fabio | First Generation MINI Tuning | 7 | Aug 5th, 2006 09:03 AM |
| Ecu Reset | Tommy T | First Generation Faults & Fixes | 19 | Jan 28th, 2006 06:12 PM |
| after changing oil - need to reset ECU? | eddieboyII | First Generation MINI Tuning | 1 | Nov 2nd, 2005 04:38 PM |
| JCW 'S' reset ECU | johnnyv | First Generation MINI Tuning | 4 | Oct 25th, 2005 01:29 PM |
