Limited Slip Differential for my MINI - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 11th, 2006, 11:32 PM
Local Time: 07:07 AM
Hello everyone!
I'm thinking about purchasing a limited slip differential for my MINI. I was thinking about installing the lsd myself, has anyone attempted this yet?
Thanks,
schatteman
Old Jan 11th, 2006, 11:41 PM
MINIAC's Avatar
Canned
Local Time: 04:07 AM
Welcome to MINI2
You might want to wade through the following thread ...
Quaife Install Thread
Old Jan 12th, 2006, 12:38 AM
MINI-Morgan's Avatar
MINI Obsessed...
Local Time: 01:07 PM
Adding an LSD will make very good difference to you cornering Dont know anyone that attempted it themselves as its a gearbox job. But no reason why you cant.
Old Jan 15th, 2006, 05:01 PM
Best Personal Regards
Local Time: 02:07 PM
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile
Done it, not a nice job but very doable. A LOT easier in a proper shop with a lift and a tranny jack. I did it in my garage, jackstands and an engine lift.
Anyways, pulling the tranny out is straightforward, splitting it to install the LSD is a snap.
You will trash the thrust bearings on the old spool trying to pry them out so you will need a pair of those. MINI does NOT sell the bearings so you have to source them yourself, using the numbers stamped on the races. As it is not a hypoid gear set, no need to preload or anything like that. In go the new bearings, you drop the spool in its place, button the sucker up and you are set. A friend will come in VERY handy if you do not have a tranny jack.
Hope this helps
Old Jan 25th, 2006, 07:38 AM
KiwiJCW's Avatar
Local Time: 01:07 AM
New Zealand
[quote=pocketrocketowner]Done it, not a nice job but very doable. A LOT easier in a proper shop with a lift and a tranny jack. I did it in my garage, jackstands and an engine lift.
Impressive. How long did it take?
Old Jan 25th, 2006, 05:28 PM
It took like a week's worth worth of evenings. Started on a Monday and had it running again by Saturday night. I figure it took some 25 hours of real work, but then again, I am not the most accomplished of machanics. Areal technician in a bimmer shop could probably do it in 15.....;except he's not allowed into the gear box
Old Jan 25th, 2006, 06:44 PM
MINI Obsessed...
I'm guessing you dropped the engine right out??
Old Jan 25th, 2006, 07:04 PM
No, I did not. I suspended it from the hoist and dropped it a tad, that is after dropping the whole subframe and front suspension. The worst part of the job is actually putting the fecking thing back in as the box is HEAVY!
I should also tell you I got good at it as I had to drop the tranny twice more while I was installing a Beta flywheel /clutch assembly. The first time the T/O bearing was wrong and the second time the pressure on the plate just shredded the material on the disc.
Do I look forward to another one?....not at all, unless in a proper shop.
Old Jan 26th, 2006, 03:49 AM
MinMax's Avatar
True Miniac
Hi KiwiJCW,
Pocketrocketowner is right, what a pain in the @r$e! But man is it ever worth it.
I've done all the mods on my MCS (which are extensive), but chose to go to Randy's shop to do the Quaife LSD, Lighweight UCC flywheel (weighed in at 10lbs) and a Stage I clutch, which I highly recommend. You might want to consider going "whole-hog" as well and do the uprated clutch and lightened flywheel at the same time, and save yourself the labor of wanting to do this later (you know it won't be long before you'll want these other mods as well .
Big kudos to Pocketrocketowner for doing this with jackstands, etc. in his garage, as it was plenty of work doing it in Randy's very nicely equipped shop with a car lift. I don't think I'd want to try this without a lift myself, especially the first time around.
I just finished bedding in the clutch, pressure plate and flywheel, and the car runs like a stripped ape! What a blast. I've heard that sometimes the lightweight flywheel can cause a bit of rattling, but as of yet, I've not noticed it. What a difference! The car feels like it suddenly lost weight, and the pedal feel is actually somewhat lighter than the stock clutch, which is the opposite of what I'd have expected from a high performance clutch.
Well worth while. Randy did an excellent job, and I learned alot, from the little bit that I helped. Only downside is that I take great pride in having done pretty much everything on my car, but it was well worth while to get the mods done.
Bottom line- I would strongly suggest considering the lightweight flywheel and clutch upgrade while you're in there, to maximize your time and effort.
BTW- Randy, Bridgett, Brian, the rest of his team, (wife and kids included) are great people, and I very much appreciated their extreme hospitality while I was there. I had great time during my visit. Thanks folks.
PS- Only thing left for me at this point is Twincharging, which I'm considering after I get healed up from this latest round of mods.
It's true, MINI mods are truly addictive, but as they say, " I don't suffer from insanity....I enjoy every minute of it!"
Cheers!
MinMax
"Super-dooper-MINI-Cooper-expert-engineering"
Old Jan 26th, 2006, 07:19 PM
GARY GP's Avatar
United Kingdom View GARY GP's Classified Ads
Thumbs up
hello i v got the 270bhp my fly wheel makes a rat rat tat tat gets on your t%ts. but its great fun!!. thanks.
Limited Slip Differential? Rutabaga Second Generation MINI Cooper S 6 Feb 20th, 2007 03:26 PM
Quaife Limited Slip Differential setox First Generation MINI Tuning 3 Oct 15th, 2004 11:25 AM
Limited Slip Differential Andromcs First Generation MINI Tuning 11 Oct 4th, 2004 03:30 PM
Limited Slip Differential Andromcs First Generation MINI Tuning 29 Aug 15th, 2004 08:47 PM
