idling problem - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 13th, 2006, 12:36 PM
Local Time: 06:40 PM
South Africa
South Africa idling problem
got problem with my mini 2002 cooper when i turn the steering side to side the idling drops , anybody know y
Old Feb 13th, 2006, 12:39 PM
MINI-Morgan's Avatar
MINI Obsessed...
Local Time: 07:40 PM
Thats normal isnt it?? to move the steering when stopped especially it requires quite a bit of hydrolic pressure created by the power steering pump.
Old Feb 13th, 2006, 12:50 PM
GR33NIE's Avatar
Polo GT Owner!
Send a message via MSN to GR33NIE Send a message via Yahoo to GR33NIE
England Male
Yep think thats normal, pretty sure the same happens on my one
Old Feb 15th, 2006, 03:30 PM
twouptons's Avatar
What's this button do?
Local Time: 01:40 PM
United States View twouptons's Pepper White & Black 1st Gen MINI Cooper Profile
Our car does that too, but I thought part of the point behind having an electric power steering pump was that it wouldn't impact the engine as much as a mechanically driven one.
A bit annoying, really.
-Eric
Old Feb 15th, 2006, 04:08 PM
Wobert's Avatar
Mr 120d Sport
United Kingdom Male View Wobert's Dark Silver & Black 1st Gen MINI Cooper S Convertible Profile View Wobert's Classified Ads
The power steering runs at c1000psi, so as you can imagine that loads the electrical system up slightly......
In the good old days of an engine driven p/s pump, the pump would draw something like 2-3 hp all the time the engine was running.
With most new cars now using an electrically driven pump, the pump is only driven when there is "high steering demand". By doing so alleviates the "drain" of the pump when the p/s is lightly loaded, eg driving along the motorway. This in turn improves your fuel economy......
The downside with the electric system is that the motor will draw load at high demand times, and as you'll probably guess, with the engine at idle speed, turning lock to lock is one of those times!
BTW turning the wheels with the vehicle stationary is bad practice, you'll wear your tyres a lot more quickly, than turning the wheel with just a small amount of forward / rear motion!
Car cutting out when idling (EMS problem?) turtle First Generation Faults & Fixes 2 Jun 18th, 2010 01:05 PM
extended idling b1motorhead General Discussion 3 Jun 20th, 2005 12:07 AM
Idling problem with 05 MCS Derm First Generation MINI Cooper S 13 Oct 14th, 2004 07:35 AM
Whine when idling? CoryB First Generation Faults & Fixes 4 May 10th, 2004 01:37 PM
Idling away... Streeb-Greebling First Generation MINI Cooper S 6 Mar 26th, 2004 12:51 PM
