40,000 Volt Ignition Coil Pack - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 4th, 2006, 12:36 PM
Billy Smart's Avatar
Hillbilly boy
Local Time: 07:40 PM
United Kingdom Male View Billy Smart's Hyper Blue & White 1st Gen MINI Cooper S Profile
What difference if any would this make to the performance if any if used with the correct leads and plugs?
Sorry for my ignorance, but if you don't ask...........
BTW mine is an 'S'
Billy
Eer you niked my son.......
Old Mar 4th, 2006, 01:06 PM
duncanbanana's Avatar
Yeah...I know !!!
Send a message via MSN to duncanbanana
United Kingdom Male View duncanbanana's Chili Red & White 1st Gen MINI Cooper S Profile
BTW mine is an 'S'
Billy
Il let you know once i get my car back , having one fitted at the moment
Quote from OutMotoring about it
"Screamin Deamon Ignition Coil Pack. The stock coil puts out 36,000 volts under heavy load, but this one puts out a shocking 40,000 volts under heavy load. The voltage increase is enough that plug gaps need to be opened up to .065 inch. This hotter spark will now travel through more fuel and air making a better burn in the combustion chamber"
Old Mar 4th, 2006, 03:20 PM
Yeah...I know !!!
Quote: Originally Posted by Max
The difference will be perceived rather than actual
a spark is a spark as sparky said
So, no great bhp improvement I regret
Not a case of great bhp improvement it Idles better, better throttle response, smoother boost.
Old Mar 4th, 2006, 03:37 PM
obehave's Avatar
Mini Mod
Local Time: 02:40 PM
Agreed.
Do NOT open the gap .065. That was tried and wasn't especially succesful.
.045 works fine but keep in mind this requires more work. More work makes the coil run warmer, warmer = won't live as long.
I am NOT implying there is a drastic life span impact. Just explaining the realities of doing this.
I have been running a .042 gap for over a year with no issues. Slightly bigger gap gives you a slightly fatter spark. Fatter spark makes for a better fuel burn.
Edit: Forgot to say I've been running the Screamin' Demon for well over a year.
Old Mar 4th, 2006, 05:27 PM
Yeah...I know !!!
Quote: Originally Posted by obehave
Agreed.
Thanx for advice , i will not open gap to .065. ill open it to 0,42 as you recommend
Old Mar 4th, 2006, 08:38 PM
obehave's Avatar
Mini Mod
Just to be thorough, leaving it at the recommended gap isn't a bad thing to do either. MOst come gapped to .036 if I recall correctly.
Old Mar 7th, 2006, 03:46 AM
Got evidence?
Local Time: 12:40 PM
United States Male View ScienceGuy's Indi Blue & White 1st Gen MINI Cooper Profile
Bingo.
These things used to make a difference in old points-n-condenser,
carburetted engines, but not on our coil-per-2 plugs, fuel-injected engines.
nake-oilsnay
Advice on Ignition Coil Pack Aberdeen Al First Generation MINI Cooper S 2 Nov 18th, 2006 10:01 PM
Help. how do i remove the ignition coil lead Richard22b First Generation MINI Tuning 0 Sep 21st, 2006 06:37 PM
Pilot Coil Pack with stock plugs? Maaij First Generation MINI Tuning 3 Jun 12th, 2006 07:22 AM
Check your ignition coil Lucas63 First Generation MINI Tuning 0 May 29th, 2005 11:58 AM
