15%-17%-19% pulleys!!! - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Sep 27th, 2006, 09:05 PM
T-bone S's Avatar
Local Time: 07:09 PM
correct - there is no pulley/supercharger change on the GP - only larger IC with revised ECU map that also increases rev limit
MY05 MINI COOPER S - DS/B - GTT OPTIMISED- THANKS FOR THE RIDE - ENTER THE R56 JCW
  #17 (permalink)
Old Sep 27th, 2006, 11:36 PM
Local Time: 03:09 PM
United States Male
being that 17's and 19's have been known to slip and also break belts due some say to them having less surface area for traction has anyone made a bigger idler pulley to change the angle of attack on the s/c pulley giving it back some traction?
  #18 (permalink)
Old Sep 28th, 2006, 01:05 AM
MINIAC's Avatar
Canned
Local Time: 11:09 AM
Quote: Originally Posted by venox22 (original)
Works Pulley - 57.9mm = 11% reduction
Someone else has measured the Works pulley at 2.21" (56.1mm) ...
North American Motoring - View Single Post - Let's Dispel the Myths!
  #19 (permalink)
Old Sep 28th, 2006, 08:10 AM
venox22's Avatar
only the brave!
Send a message via AIM to venox22 Send a message via MSN to venox22
Local Time: 08:09 PM
United Kingdom Male View venox22's Indi Blue & White 1st Gen MINI Cooper S Profile
is that measuring the tips of the vee grooves or not??
  #20 (permalink)
Old Sep 28th, 2006, 11:00 AM
Perm's Avatar
BBR use a cosworth idler with their 19% reduction pulley. This special idler is designed to allow for the std belt to be used.
Regards
Perm
  #21 (permalink)
Old Sep 28th, 2006, 11:10 AM
MINI 2 Sponsor GT Tuning
United Kingdom View roland2003's Classified Ads
Hi Herbie, yes the GTT Idler Pulleys are available in larger diameters to do just that! 'improve the angle of attack' (nicely phrased btw). Also the GTT T/B Idler Pulley is the ONLY one using two bearings to properly support the pulley ,(one either side) to reduce bearing wear & movement / slop . It's also hard anodised alloy so is light weight yet resists wear very effectivly.
Check our website below for more info.
Best Regards Roland GT Tuning .
  #22 (permalink)
Old Sep 28th, 2006, 11:12 AM
venox22's Avatar
only the brave!
so would you reccommend doing the idler pulley and the tensioner pulley at the same time??
  #23 (permalink)
Old Sep 28th, 2006, 12:51 PM
Hi Vennox, yes idealy as both run on the back face of the drivebelt. The Idler does take alot more load though ,hence why its available from us as a Twin Bearing Upgrade Pulley.
  #24 (permalink)
Old Sep 28th, 2006, 01:05 PM
venox22's Avatar
only the brave!
Thanks Roland, thats cleared it up for me!!
So your GTT idler pulley uses a twin bearing design as it carrys more load.
And your GTT Tensioner pulley uses a single bearing design as it doesnt carry as much load as the Idler pulley
  #25 (permalink)
Old Sep 28th, 2006, 11:47 PM
United States Male
Regards
Perm
that's cool must be bigger so traction would def. be restored
  #26 (permalink)
Old Sep 28th, 2006, 11:50 PM
United States Male
wow i'm waaaaaay behind the curve on this one . sounds wicked ******a .
  #27 (permalink)
Old Dec 29th, 2009, 02:51 PM
Local Time: 09:09 PM
Cyprus View PeteMike's Classified Ads
Not sure if this was answered in this thread but and suggestions to pulley manufacturers? I am looking for a 15% reduction for an 05 stock cooper s.
  #28 (permalink)
Old Dec 29th, 2009, 04:48 PM
DaFlake's Avatar
MMC Member
Local Time: 02:09 PM
KMT, Alta, Mini Madness etc....
KMT seems to be the choice over there but any will do.
  #29 (permalink)
Old Jan 25th, 2010, 02:57 PM
Still looking for a pulley here. Anyone know where to find good deals on pulleys that ship to Cyprus?
Also, do I need to change the belt if I get a 15%?
  #30 (permalink)
Old Jan 25th, 2010, 04:38 PM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
yes you will need a shorter belt. i have a black 16% pulley for sale if your interested? PM me if interested
Running 211whp
Tags: ,
Supercharger Pulleys Black Works First Generation MINI Tuning 9 Oct 21st, 2006 10:13 PM
Pulleys Fisher First Generation MINI Tuning 0 Jun 28th, 2006 12:59 PM
Reduction Pulleys... MiniLover247 First Generation MINI Tuning 2 May 21st, 2006 05:58 AM
belt for 15% pulleys holdenontoit First Generation MINI Cooper S 8 Jan 30th, 2005 11:21 AM
sqeaking pulleys or something else ? evo6stu First Generation MINI Cooper S 2 Jul 10th, 2002 09:00 PM
