question about pulley reduction - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 10th, 2006, 05:58 AM
MINI-LOVER's Avatar
Local Time: 12:42 PM
Mexico Male View MINI-LOVER's Chili Red & White 1st Gen MINI Cooper S Profile
DIY question about pulley reduction
hi,
I'm thinking of getting a 19% pulley reduction on my MCS '05, which, until now is completely stock.
my question about it is wether i need to do something else to the car, like an ECU remap? or other parts as well? or can i just do that and leave the rest of the car alone?, I've never done anything like this to a car in my life, so I'm really lost in this subject...
How wide is the hall-way, Napster?
Old May 10th, 2006, 06:33 AM
St00ge's Avatar
8/10 on the Stoogometer
Send a message via MSN to St00ge
Local Time: 04:42 AM
Australia Male
no you don't need to do anything at all, just add a shorter belt instead of the original.
You well get the full benefits of the added boost with a remap and bigger injectors
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
Old May 16th, 2006, 02:13 AM
hyprblu's Avatar
Local Time: 05:42 AM
Australia Male
Sorry Elie but you missed something......Make sure that you install colder spark plugs or you may get pre detonation which will wreck a cylinder if it happens. There are plenty of threads on Mini2 which cover this.
Old May 16th, 2006, 07:46 AM
St00ge's Avatar
Australia Male
ah yes, but this is a topic of much heated debate. If you were to get a bad batch of fuel, and your knock-sensor fails to work, you might blow a spark plug if you have stock plugs, but if you pre-detonate while you have colder plugs, yes you'll save a $20 spark plug, but you might damage your cylinder. Some tuners in america actually recommend that you don't fit colder plugs.
That all said, i'm no mechanic, and we don't get fuel that's that bad over in aus, and i run a 17% pulley with colder densos, but i have run it on stock plugs as well, and noticed no difference, ran perfectly with both.
BTW where have you been richard? Haven't seen you on here for a while
pulley reduction zippyy First Generation MINI Tuning 7 Nov 27th, 2006 11:47 PM
Ultrik 15% reduction pulley pubert First Generation MINI Tuning 8 Jul 17th, 2006 08:10 AM
15% reduction pulley ScottishcooperS First Generation MINI Tuning 27 Dec 7th, 2005 07:25 AM
15% reduction pulley Idontbrakeforcorners First Generation MINI Tuning 13 Dec 23rd, 2004 12:09 AM
