| GRS Intercooler... DIY ? Yes or No ??? Hi, Im looking to purchase the GRS intercooler for my MCS in the next couple of weeks and I wanted to get a feel for the size job it is ?. I have fitted springs and shockers in the past aswell as exhausts and induction kits. But I havent done any intercoolers. Mainly because I havent had a supercharger before .So, anyone who has fitted one themselves could give me an idea of the tools need ? and an idea on how difficult it is that would be grand ? Cheers! |
| Cheers etalj. Sounds like its just plug and play ![]() I noticed you have the Alta induction kit from your signature, is there any interference between the two in terms of the size of both units ? |
| If you can do the other stuff, the IC is a walk in the park. Simply unscrew the IC cover, undo and remove the clamps, remove the boots/IC. Undo the rear mount for the IC, remove, and replace the bolt, undo the front mount and remove it. Slot the GRS in, bolt her down, and she's ready to do. The diverter, its a matter of a couple of screws and nuts - so simple I don't need to explain it to be honest, you'll see it once you look at it. No problems at all with the Alta + GRS combo. Also not, Grahams instructions are *REALLY* good and have full pics, so you have even less reason to worry . |
| GRS by far. I've compared the two side by side, the GRS is a much nicer piece of kit, looks a hell of a lot better than the GTT, has a much nicer diverter setup, and is actually bolted in place like the stock IC so it doesn't rattle like the GTT does, which just floats around. |
| The alta CAI doesn't interfere at all with larger ICs (even tho i don't own a larger IC, i'm saving up for a M7 DFIC). The IC is extremely easy to take off and put on, i can't think of any other component that's as easy to remove/replace. Good luck, enjoy the IC Black MCS |
| http://www.grsmotorsport.co.uk/ is the website. Its a perfect fit, its not just an intercooler its a work of art. They really are a fantastic piece, the quality is phenominal, its just gorgeous. |
| I'm a CAI 'Ho Bought one of the first BMP kits first Alta kits and now the HDI.. Actually I've always wanted a closed box and had even done home made tops for my Alta. When the HDI came out I jumped on it. Of course 2 weeks later (approx) Alta comes out with a top. If they had done so sooner, like I and others had requested for a looong time, I might just have stuck with my Alta. It's a good kit. Want to buy it?? But that's the reason. Both are good kits The advantage for me with the HDI is it made it easier to run the cables for my UniChip and it's shiny Last edited by obehave; May 29th, 2006 at 03:27 AM. |
| How good is the GRS Intercooler.......... | Paul@1320 | First Generation MINI Tuning | 43 | Sep 26th, 2007 12:16 AM |
| GRS Intercooler | djwoody | First Generation MINI Tuning | 3 | Aug 25th, 2007 09:01 PM |
| GRS Intercooler supplier in OZ? | The Artist | Australia | 21 | Oct 15th, 2006 01:06 AM |
