| The problem with the MINI's cooling system is that there's no real way of getting all the old coolant out. When you disconnect the lower radiator hose to drain the coolant, the expansion tank and radiator will be drained but not much from in the engine. The engine block drain is not accessible without removing the starter (I believe). Also, when you fill the system back up, it won't start flowing until the thermostat is open. I recommend filling the upper radiator hose through the bleed valve in order to get some coolant in that area.
When I did this last year, the engine temp gauge went up about 2/3 and I turned the car off. After letting it sit for a few minutes, I started it back up and everything seemed to flow fine.
Bleed the system through the screw on the upper radiator hose several times to get all the air out. |
