Foam Air Filter Vs. K&N Air Filter--which one to choose? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 18th, 2006, 03:36 AM
Zipperblues's Avatar
Send a message via AIM to Zipperblues
Local Time: 02:43 PM
United States Male
After reading all the different companies propaganda, I am completely lost on what air filter to buy. I’d like to get the best filter, which would allow my MINI to run as well as possible for as long as possible. Money is no object. Is the standard paper filter the best? Or is a K&N or foam filter best? I was considering giving this a try. http://new.minimania.com/web/Item/NME2101/InvDetail.cfm Anything you can tell me about the different air filters, and their pros and cons would be much appreciated.
And while I’m at it, is the Fram Extra Guard oil filter any better than the standard filter?
I want to make sure my car is as healthy as possible, so any recommendations would be appreciated.
Thanks!
Old Jul 18th, 2006, 03:58 AM
St00ge's Avatar
8/10 on the Stoogometer
Send a message via MSN to St00ge
Local Time: 04:43 AM
Australia Male
A Cotton filter will flow better than a Foam filter when both are clean, but when you get a few miles/km on them, the Foam will outflow the Cotton.
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
Old Jul 18th, 2006, 07:30 PM
United States Male
I got impatient and ordered the foam filter. I decided to do this because my brother told me that now all dirt bikes come with a foam filter stock. That alone convinced me.
Old Jul 19th, 2006, 01:03 PM
BlueZed's Avatar
Staying shiny-side up!
Local Time: 06:43 PM
Ireland Male
Foam or cotton?
I've used K&Ns in all of my cars prior to this and found them very good, but I've gone for a PPX foam insert this time for variety
I noticed pretty much no extra noise after fitting but the car seems to rev a little smoother.
One thing I might try later is to isolate the resonator attached to the airbox as this saps the induction noise a little bit. I removed it completely on a Focus and it gave a lovely extra growl under load. Might be worth a go if you don't want the extra expense or for some the excessive noise of an induction kit. Each to their own though really.
What new bits? I didn't buy any new bits...
Old Jul 19th, 2006, 08:13 PM
United States Male
I was worried about K&N because I heard that they just let all the dirt through. I'm glad to hear someone else here has used a foam filter before. Let me know how your above mentioned mod turns out. I don't want to change anything major on the car until I pay it off, but that seems like a good temporary mod.
Old Jul 20th, 2006, 09:16 AM
St00ge's Avatar
Australia Male
i have a foam filter on my car. So do heaps of ppl with MCSs. The ALTA cold air intake uses a foam filter.
Old Jul 21st, 2006, 10:00 AM
BlueZed's Avatar
Ireland Male
Who told you the K&N would let all the dirt through? It's less restrictive than the paper ones but it should still be trapping the dirt particles that will damage your engine. If it did that they wouldn't be selling filters for very long! A version of the foam filter Pipercross make is used in the Cooper Sound kit and their whole selling point for the Works kits are that they are tested intensively to retain BMW approval in terms of your warranty so I find that a pretty good reason for choosing this option.
As I said previously there isn't much noticeable noise but response is better and it pulls a bit harder when booting it above 4500rpm. Worth doing, but I will have to see how it sounds in a year or two when I replace the exhaust
Old Jul 26th, 2006, 03:56 PM
United States Male
Well, I just put in my foam filter and went for a test drive...
Its great. It really does feel smoother and it seems to have a little more pep. It may have sounded a tiny bit louder, but not enought to go out and buy one if you want more noise.
Overall, I'm very happy.
Old Jul 27th, 2006, 08:39 AM
BlueZed's Avatar
Ireland Male
Yep you sound as mega-excited as I did after fitting it
It's definitely a very subtle mod that only the driver will notice really.
I think the next thing I will have to do is get a Bluefin anyway, that'll make better use of the extra airflow and hopefully improve the throttle response below the magic 4.5k. Like I say I'll fit a new exhaust in a year or two and then consider an induction kit depending on whether I want a bit more roar or not.
Old Jul 27th, 2006, 11:07 AM
MiniBimmer's Avatar
Local Time: 07:43 PM
Portugal
Hello
In relation to filter JR which your opinion?
Best Regards
Old Jul 28th, 2006, 12:20 PM
Wales
Cotton air filter with cold air feed, if you dont have cold air feed then the induction kit can only utilise the 'hot' engine air. Foam filters deteriorate, cotton needs cleaning.
Old Jul 28th, 2006, 01:39 PM
BlueZed's Avatar
Ireland Male
Induction kits probably do benefit from a cold air feed, but the standard airbox as discussed here is sealed and has a cold air feed from the front of the car as standard.
Would you be of the opinion that the foam will deteriorate with physical wear e.g. rubbing against the soundproofing under your bonnet, or from general use?
Old Jul 29th, 2006, 12:31 AM
United States Male
christ just pick one and enjoy ...we're talking about what? 1 h.p.? the price is not that diverse . so do it up man!!!
Old Jul 31st, 2006, 08:12 AM
BlueZed's Avatar
Ireland Male
I already did mate!
Just waiting for the magical Cooper ECU to adjust the car to 219BHP so I can waste some GP owners!! :bigg rin:
  #15 (permalink)
Old Jul 31st, 2006, 12:24 PM
Bayliner's Avatar
Local Time: 08:43 PM
Netherlands Male
I would go, and in fact I went, for the pipercross filters.
The foam filters (Pipercross) produce a very very very nice sound. The none foam filters produce a different sound, more high frequent. Installing a foam filter will give you the sound and volume of a sports exhaust!
Pipercross filters 90% wen dry and 99% when wet (oiled).
The foam filters have the highest flow. And can also be cleaned.
Get one with a vector cone, they have zero turbulance and will give the best results
K & N Air Filter Vs JCW Filter? envy First Generation MINI Tuning 3 May 31st, 2006 02:38 PM
K& N Air Filter adampoon First Generation MINI Tuning 11 Mar 19th, 2003 10:06 PM
K&N air filter GR8SHAG First Generation MINI Tuning 8 Dec 29th, 2002 02:08 AM
K&N air filter wdfoto First Generation MINI Tuning 5 Sep 16th, 2002 06:16 PM
K & N air filter Mugami First Generation MINI Tuning 8 Jul 1st, 2002 05:55 PM
