Metal glue - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 22nd, 2006, 08:30 AM
GTT 280's Avatar
The Power Cube
Local Time: 07:45 PM
United Kingdom View GTT 280's Classified Ads
United-Kingdom Metal glue
All,
Does anybody in the UK know of a metal glue that is good for steel and aluminium?
Cheers,
K.
Old Nov 22nd, 2006, 08:32 AM
sel's Avatar
sel
bye bye MINI hello 206
Local Time: 06:45 PM
England Female
are you tryin to stick.....
metal to metal??
metal to plastic??
metal to.....
Log on to www.newminikernow.co.uk and check out what's happening in Cornwall
Old Nov 22nd, 2006, 08:38 AM
GTT 280's Avatar
The Power Cube
Metal to Metal
Quote: Originally Posted by 260 GTT (original)
All,
Cheers,
K.
Steel to Steel and Alu to Steel, oh, and Steel to Alu, possibly even Alu to Alu.
So yes, definately a METAL GLUE
(you were joking right?)
Cheers,
K.
Old Nov 22nd, 2006, 09:13 AM
Shorty's Avatar
Send a message via Yahoo to Shorty
England View Shorty's Solid Black & Black 1st Gen MINI Cooper S Convertible Profile
Cheers,
K.
Are you sticking that front grille badge on?
If you are, let me know how you get on
Old Nov 22nd, 2006, 09:16 AM
GTT 280's Avatar
The Power Cube
Arrow Laugh
Yes, I am.
Instead of just glueing it in place, i am going to unbolt the JCW badge and then glue two bolts to the back of the GTT badge, then bolt it in place.
Hence the "Does anyone know of a good METAL glue?" question...
Full removal of the front bumper required too, so also need to find out where to place axel stands... nothing is straight forward is it....
Cheers,
K.
Old Nov 22nd, 2006, 09:27 AM
So Say We All
United Nations View Haggi's Classified Ads
hmmm i remeber to stick stuff to aluminium can be tricky when i broke stuff at work but roland acctuly had a post about this and they made a separte plate bolted that through the grill and then used some sort of silicone sealer to attch the badge to the plate as i know form repairng and sealing bits of the plant at work slicnoce and aluminium stick quite well
also due to the nature of the grill its not adviabe to stick stight onto it hence the backing plate
minitorque.com, the site for mini performance, drag racing track days & time attack
its all change for the S, to be revealed soon
Old Nov 22nd, 2006, 09:47 AM
GTT 280's Avatar
The Power Cube
Thumbs up Good man
nice info.
Cheers,
K.
Old Nov 22nd, 2006, 09:58 AM
G-Man's Avatar
Cool CoopS
England Male View G-Man's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
I used a hot glue gun to put my AC Schnitzer badge on my grille and its still on there a year and a bit later.
Old Nov 22nd, 2006, 11:34 AM
GTT 280's Avatar
The Power Cube
Thumbs up Nice idea
Was the back of your badge smooth metal? I imagine the hot glue had the benefit of bonding with the plastic grille more than cold silicone?
Am still favouring the metal glue with bolts as a permenant fixture.
Cheers,
K.
Old Nov 22nd, 2006, 11:41 AM
So Say We All
hot glue is good beacuse it still retains as certian ammount of vicousness and dosnt totaly solidify much the same as silicone but from stuff ive repiard at work i know siliconce dose the trick on a long tream (parts on grain dyrers exposed to heat and frost in equal measure) and it holds (dosent stick rubber very well thow for some resaon)
also if at any point you wish to remove it id opt for bolting as if its siliconed stright on rather than to a backing plate dont expect an easy time removing the silicone as if glue in stright on go for the hot glue as its easier to remove
Old Nov 22nd, 2006, 01:00 PM
What about JB weld? Worked great for sticking additional aluminium air diverters on my GRS intercooler.
Old Nov 22nd, 2006, 01:27 PM
G-Man's Avatar
Cool CoopS
Ya it is smooth aluminium about the same size as the JCW badge.
Old Nov 22nd, 2006, 02:06 PM
GTT 280's Avatar
The Power Cube
Kwik weld - withstands temps up to 150 oC, tensile strength 2500lbs (148kg/cm2) bonds metal, plastic, ceramic, wood, masonry and glass. Cures in 4mins full strength in 20mins. Emergency repairs, seals water leaks in pipes and tanks.
Where do you buy it from?
Cheers,
K.
Old Nov 22nd, 2006, 02:10 PM
I think I have seen it in Halfords. If not, you can easily order it off the Internet.
  #15 (permalink)
Old Nov 22nd, 2006, 04:46 PM
MINI 2 Sponsor GT Tuning
United Kingdom View roland2003's Classified Ads
Clear bathroom silicon sealant works very well for this, we also use it to affix many of the TT interior trim parts we do. Needs a warm garage to set enough to stay in place after 5 mins. Nice & strong ,sticks to most surfaces,even uneven ones (plastic, ali, stainless etc) ,yet can be pulled off (just) if you need to. Metal glues (araldite etc) are IMO a bit OTT for a badge
Best Regards Roland GTT
ahhhhhhhhhhhhhh super glue on paintwork Kaj First Generation MINI Exterior 3 May 23rd, 2005 04:27 PM
mcs no longer sticks like glue to the road oopsdy First Generation MINI Cooper S 3 Sep 10th, 2004 04:29 PM
Glue-Like Smell Inside My Cooper b.dazzled First Generation Faults & Fixes 1 Jun 26th, 2004 03:55 AM
Metal to Metal screeching sound WAY First Generation Faults & Fixes 6 Aug 27th, 2002 08:34 PM
