| Want a Re-map on my Cooper!! Which is best!!? Been looking around for a re-map on my cooper!! Seen people quoting jumps from 115Bhp (standard) to 135Bhp!! Seems a big jump to me and really interests me!! Also the fact it wipes out all flat spots and makes the acceleration smoother and more powerful!! Just a couple fo questions: 1). This wont alter the sound of the car will it, as I dont want it to sound like an exhaust has been put on, etc!! Just want it to sound standard but be more powerful!? 2) Which is the best re-map avaliable and where can I get it done, also what price!? 3). ARE THEY REALLY WORTH IT AND WILL I NOTICE THAT MUCH DIFFERENCE!?? Cheers |
| Simple really. For ease and sucurity you are best off with a superchips bluefin on the cooper. The AMD and MTH maps (the next two biggest map tuners for the MINI from what I can tell) are not difficult to do but as far as I'm aware they don't carry a warrantee. Once fitted your BMW warrantee on anything effected by the map change is void. If you get a superchips bluefin (usually a bit more expensive than AMD or MTH) then superchips have thier own warrantee, check this out, but i'm sure I'm right. You'll get about 130ish BHP from any of the maps available including the superchips one so with regard to power theres not really a point in shopping...shopping on the Cooper map is down to saving money and warrantees not the power hike. |
| The AMD one does have a warrnaty. Also bear in mind AMD are very well respected ( or were before everyone left them) and have done work for manuafturers, in fact the last car they were responsible for was the limited edition VXR 220 |
| The S map is different to the one used on the Cooper and ONE. The map used for Coopers and ONE brings either car to approx 130 bhp from the standard 90 (?) or 115 bhp. Therefore the Cooper/ONE map provides 30ish/15ish BHP respectivley (this is based on if your car was pushing out the standard factory stated bhp at the start...many are not!) The S map only provides the S with 8 bhp over the standard 163 ...not sure what it gives to facelift (July 04 onwards) Cooper S's (Normally 170 as standard) This is all dependant on your car of course. Some cars are way down on power and others will register higher than factory even when standard. I have an 02 S which appears to be a really sweet vehicle in terms of engine quality/power. When rolling roaded it threw out over stock levels and had one of the best (smooth) power and torque curves i have seen on a standard factory car thats been on a RR (no major dips in power or torque and nice and even increase right to peak levels). However there are plenty of cars including JCW models that don't achieve anywhere near the power they are supposed to...an example is a JCW 200 (Pre 210 model) that has been RR several times and never acheived over 195 bhp!! Its like the pot luck thing you get with some cars being Friday afternoon cars and having loads of faults and some that are really tight and never have anything wrong with them. Its all pot luck and very much dependant on the fuel you use too. R |
| Oh and BTW I agree the AMD are very very good. I was just not sure if they supplied a warrantee like Superchips...If they do then thier maps are just as good as Superchips IMHO from knowing folks with them. Basically the Cooper and ONE are capable of around 130-140 bhp depending on what map and mods you run. I know there are a few Coopers out their running quite nice set-ups and obtaining 140ish bhp...after this the gearboxes start to get to be a worry rather than the engines from what I have seen over the years. Just with a map (of a good quality) you should achieve 125-130 if your car was half decent to start with...if you have a good exhaust, manifold and induction kit then you can look at achieving higher than 130...especially if you run a custom map from superchips, AMD or MTH thats specifically mapped for the extra performance bits on your car. Oh and just mapping the car won't make a differnece to the noise...what does that is the silencer and exhaust/manifold bore, and induction kit...if they stay stock then other than possibly a bit more popping on over run you'll not notice any external or internal noise changes. |
| best re map for cooper s??? | philly c | First Generation MINI Tuning | 6 | Apr 17th, 2007 05:48 PM |
| Should I get a re-map of a re-map | Richard22b | First Generation MINI Tuning | 5 | Apr 6th, 2007 05:05 PM |
| Anyone Replaced their BBR map with a MTH map ? | Perm | First Generation MINI Tuning | 0 | Aug 26th, 2005 10:47 AM |
| which re-map ??? | supercharged99 | First Generation MINI Tuning | 8 | May 24th, 2005 10:55 PM |
| Can a re-map add 31bhp to a 'pullied' Cooper S ? | roland2003 | First Generation MINI Tuning | 7 | Jul 1st, 2004 11:18 PM |
