Engine problem Hello! I have a Mini Cooper S -05 and I have change pulley 19%, colder spark plugs and change software. The engine is ok when it is cold but when it is full (90 degree) temperature the engine compensate, snatch little and the engine give not full power, have some one else have that problem? I hope you understand my not so good English. // Klabbe |
| what software do you have?? what belt did you usewhen you swopped the pulley?? First M45 Cooper S to run a 12 (12.96@105) On Nitrous 11.16@123 0-100 7.1991 ![]() http://www.1320MINI.co.uk |
Hello! We have now change the software to original and change the pulley to 0% but that is the same problem, when the engine I cold it is ok but when the temperature rise the engine compensate, snatch little and the engine give not full power. I have change the air filter and the oil in the filter can broke down the sensor in the air quantity meter (I don’t now the English word for it but I Swedish we call it “luftmassemätare”) but when I look in BMW part catalog I cant fond it? What control the air temp or quantity on the Cooper S engine ? // Klas |
| I think that the luftmassematare that you are referring is a map sensor in English. (rough translation with what I could find). That being said, the symptoms that you describe seem like a super charger bypass valve gone or going bad. Detroit Tuned // Detroit Tuned Bypass Valve |
| Can I check the bypass valve or can I BMW dealer do that without to change the valve? When I drive at 2000-4500rpm the engine look like to give full power but from 4500-6900rpm it compensate, snatch little and the engine give not full power but when the engine is cold it give full power from 2000-6900rpm. Can a broken air sensor give this problem to? |
| Air sensor ? Which one is the dubbel air sensor, temp and pressure, the one in the intake manifold RealOEM.COM * BMW R53 Cooper S INTAKE MANIFOLD SYSTEM hg=11&fg=40 09 MANIFOLD AIR PRESSURE SENSOR 1 12140872679 or RealOEM.COM * BMW R53 Cooper S WATERPUMP - THERMOSTAT hg=11&fg=35 12 MANIFOLD AIR PRESSURE SENSOR 1 12140872648 Quote: Originally Posted by Klabbe (original)Can I check the bypass valve or can I BMW dealer do that without to change the valve? When I drive at 2000-4500rpm the engine look like to give full power but from 4500-6900rpm it compensate, snatch little and the engine give not full power but when the engine is cold it give full power from 2000-6900rpm. Can a broken air sensor give this problem to? I have now change the bypass valve but I have the same problem? can it be one of the air sensors? or what ? Please help me. // Klas |
| Engine Problem! | joer-r | First Generation Faults & Fixes | 7 | Mar 28th, 2005 06:28 PM |
| HELP - gearbox or engine problem | asinn | First Generation Faults & Fixes | 4 | Aug 7th, 2004 06:42 AM |
| Service engine soon problem | jdbergz | First Generation Faults & Fixes | 3 | Apr 22nd, 2004 07:41 AM |
| Help, S Engine Problem? | Parky | First Generation MINI Cooper S | 2 | Jun 8th, 2003 11:37 PM |
