What coolant should I use? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 10th, 2007, 12:06 PM
fergusor's Avatar
Local Time: 08:31 PM
Hi Guys,
I have an '05 MCS and whilst washing it yesterday I noticed the coolant bottle was almost empty.
I checked the handbook and it says that I can't use just any coolant for it. Does anyone know what I should be using... what do MINI/BMW recommend?
And should I be worried about the bottle level being so low? The car was serviced about 6000 miles ago.
Thanks,
Richard.
Old Jun 10th, 2007, 07:43 PM
JohnWB's Avatar
United Kingdom Male View JohnWB's Laser Blue & Black 2nd Gen MINI Cooper S Profile
Just get a bottle of the Mini antifreeze then you will not have any worries
Laser Blue / Black MCS - Arived March 07
Old Jun 10th, 2007, 08:13 PM
marcy's Avatar
howay the lads
Local Time: 09:31 PM
England Male
youl need green antifreeze theres red/blue/green differant coulors for differant cars minis youse green or can cause engine damage any motor shop will tell you as for the level been down check for leaks around pipes you shouldnt loose any unless its mixing with the oil lift oil cap off if theres a white gunk in the oil filler then theres water in the oil and that could be head gasket or worse but youd know if it was that temp gauge would be up
Old Jun 11th, 2007, 10:21 AM
fergusor's Avatar
Thanks for the advice. I've checked under the oil cap and it's clean so I'm guessing it hasn't leaked into there. When driving the temperature guage doesn't go over normal so it's not overheating either.
I'm going to call the MINI dealer this morning and possibly get it booked in to check out. In the meantime I'll get some coolant from the dealer and fill it up.
Coolant dreamydaniel Maintenance & MINI Care 2 Sep 4th, 2006 10:30 AM
Coolant? Ginger First Generation Faults & Fixes 17 Sep 13th, 2004 09:04 PM
Coolant ruthie Maintenance & MINI Care 2 Feb 26th, 2003 07:59 PM
More Coolant? xnetco Maintenance & MINI Care 6 Jan 30th, 2003 11:55 AM
