Removal of Air-Con - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 19th, 2007, 12:17 PM
GTT 280's Avatar
The Power Cube
Local Time: 07:49 PM
United Kingdom View GTT 280's Classified Ads
Question Removal of Air-Con
I was wondering if it would be worth removing the air conditioning unit in my vehicle.
I never use it, and it could be blocking vital cool air flow to my radiator.
How much does it weigh, could it be installed in someones MINI that does not have air-con?
Could the switches used to control the aircon be used for other purposes, like water jets on the radiator etc.
I'm considering getting a few water jets applied to the intercooler and radiator anyway...
Could the air con be used to cool the intercooler/radiator, instead of water jets?
Hmmm, interesting.
Cheers,
K.
Old Jul 19th, 2007, 12:58 PM
MINI 2 Sponsor GT Tuning
United Kingdom View roland2003's Classified Ads
.. +turbo
Air con removal, improves fuel consumpsion , less weight, better rad cooling, less to go wrong, longer belt life (in theory) ..and you can always open the window...
Old Jul 19th, 2007, 01:22 PM
GTT 280's Avatar
The Power Cube
...sold.
For my information... can you itemise and cost up a turbo mod for my car please. Email when you next have time on your hands.
However, i really like my 270bhp supercharger car (its awesome), so i need convincing. I'd like a trip in the GTT300T first ;-)
Cheers,
K.
Old Jul 19th, 2007, 02:05 PM
alski's Avatar
dyno-mite, might not....
Local Time: 06:49 PM
England Male View alski's Classified Ads
why not direct cooling to air box, rather than cabin? ten degrees less must be worth a few hp?
carefree
Old Jul 19th, 2007, 02:10 PM
hi Karl, come to the Castle Combe trackday end of Sept....i'll take you round.
We can take all the aircon off at the same time as the turbo conversion no problem.
best Regards Roland GTT
Final GTT300T testing will be during August. Exact spec & pricing will then follow.....
Old Jul 19th, 2007, 02:15 PM
GTT 280's Avatar
The Power Cube
Unhappy Unfortunate timing
Many thanks for the offer but i am in Malaysia again during Sept/Oct :-(
We'll have to organise something though.
Cheers,
K.
Old Jul 19th, 2007, 09:31 PM
robbo mcs's Avatar
Track Addict
Local Time: 05:49 AM
Australia View robbo mcs's British Racing Green & White 1st Gen MINI Cooper S Profile
Hi,
I have removed the airconditioning from my car. It weighs around 5kg in total. Some people run a dummy AC idler wheel. I don't, which means the belt length changes slightly.
The only problem I have had is sometimes in rallies when it is very wet you can get problems with the car fogging up. The AC is very useful in these conditions, as running the demister on warm, with the AC on is the best and quickest way to clear the windows (as the AC dehumidifies as well as cools).
Also, the first event I did after removing it, it was 42C, and sitting in a triple layer racesuit, with nomex underwear etc was a little toasty, and I wished I had it for laison stages
As for the suggestions of feeding the cold air into the airbox or radiator etc. This is really "parasitic", ie you use power from the engine to drive the AC, and you would get less power back.
BTW, the porsche turbo does use a similar principle, using the AC to cool the fuel rails to increase the density of the fuel. For this reason people who race and rally turbos never remove the AC.
Robbo
Mods: Hartge kit, CAI, oil cooler, headers, cat & exhaust, bilstein coilovers, adjustable bars & camber plates, quaife diff, roll cage, seats, harnesses
GO MADDIE and SPARKY!
Old Jul 20th, 2007, 06:47 AM
GTT 280's Avatar
The Power Cube
...nice info, thanks.
Yes, agree that using the AC to cool anything in the engine would be more parasitic than productive.
5kg - not that heavy then
Cheers,
K.
Old Jul 20th, 2007, 06:56 AM
Paul@1320's Avatar
MINI2 Sponsor
For the weight loss I wouldn't bother either, also IF you ever sell the car having aircon will defintley be an advantage.
First M45 Cooper S to run a 12 (12.96@105)
On Nitrous 11.16@123 0-100 7.1991
http://www.1320MINI.co.uk
Old Jul 20th, 2007, 08:12 AM
GTT 280's Avatar
The Power Cube
Thumbs up Air con removal
Ah... but the aircon will be going, it is making way for the 350bhp turbo mods next year.
I don't think i will ever sell this car - it's just too trick now.
Cheers,
K.
Old Jul 20th, 2007, 08:44 AM
Paul@1320's Avatar
MINI2 Sponsor
I thought that might be your reply
Old Jul 20th, 2007, 03:42 PM
Hi, running witout aircon and NOT fitting the 'aircon delete pulley assembly' loses about 30% of 'wrap' around the SC pulley and also similar on the alternator pulley. We had one in last week with this mod...weve now fitted 'aircon delete pulley'.....IMHO much better as less risk of belt slip.
Best Regards Roland GTT
Old Jul 20th, 2007, 04:23 PM
GTT 280's Avatar
The Power Cube
i take it that the air con pulley is constantly being driven, and therefore utalising some power all of the time. What drag is does it impose?
Assume the delete aircon pulley is a good part similar to the twin bearing idler pulley?
Cheers,
K.
air con minin me First Generation MINI Convertible 4 Oct 4th, 2005 09:46 PM
Air Con mini_coop_her First Generation Interior & Ice 5 Apr 22nd, 2004 06:45 AM
Air-Con / Auto Air-Con / Climate control ??? fitzsimonss First Generation MINI One 13 Apr 19th, 2004 09:44 PM
Air Con UKminiowner First Generation Faults & Fixes 3 Mar 15th, 2004 02:00 PM
Air Con Intrepid First Generation MINI Cooper 7 Aug 21st, 2003 10:32 PM
