Importance of ECU remaps: discussion and results - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Jul 30th, 2007, 08:52 AM
DaFlake's Avatar
MMC Member
Local Time: 04:14 AM
The idea behind it is that heat soak causes a loss in power. Typically I would agree but I think that it will vary region to region. When I lived in Texas, I would have definitely looked at something like that, but being over here in Germany, the climate is much better and it may not really give you much.
  #17 (permalink)
Old Jul 30th, 2007, 09:08 AM
ScottyBoy's Avatar
Obsessive Car Cleaner OCC
Local Time: 09:14 AM
As always when you have members with a wealth of knowledge as above from everyone then you can learn something i just wish i knew alot more!
  #18 (permalink)
Old Jul 30th, 2007, 09:18 AM
DaFlake's Avatar
MMC Member
That is one of the great things about this forum. Lots of great information. However, that is also the downside. Lots of misinformation.
I learn new things everyday.
  #19 (permalink)
Old Jul 30th, 2007, 09:20 AM
ScottyBoy's Avatar
Very true!
  #20 (permalink)
Old Jul 30th, 2007, 09:28 AM
sam_a156's Avatar
Flying Finn
Send a message via Skype™ to sam_a156
Local Time: 10:14 AM
Poland Male View sam_a156's Dark Silver & Black 1st Gen MINI Cooper S Profile View sam_a156's Classified Ads
That being said, do you consider a 15% pulley a minor mod? I certainly don't as you are severely altering the amount of air being shoved into the engine. As you start making changes to the HP, you have to tell the engine what you are doing. That being said, I really think that most people don't really understand what a remap is and should do. The hype is that you can increase HP with it. Sure, this can be done and is a side affect of doing it but it is not the only reason for doing it. What you are really doing is letting the car know what you have done to it and adjusting it accordingly. Back in the old days, you would do a tune up to get the car running better with the parts that you have put on. Well, that art is now in the forum of an ECU.
With the above in mind, to summarize, this is my reasoning:
1) I saw on numerous dyno tests how much the JCW parts were worth without a remap. Say a tad over 50% (of the promised power increase). The remaining 50% or so was up to the ECU remap.
2) With a larger crank shaft pulley, modified bypass valve, JCW airbox mod+filter and a manifold I assume that my car now already differs quite a bit from a standard JCW. I therefore further assume that the standard JCW ECU map will not necessarily be any more ideal.
3) GP has a slightly tweaked ECU map with a raised rev limiter (7100?). As far as the latter, I would not go for anything crazy, but perhaps 7200/7250. I guess this is roughly what you get from MTH.
These are the three main drivers why I am curious about what a professionally made ECU tune could do for me at this stage. But again, to be clear, I do not expect the difference to be as dramatic as in the case of my JCW upgrade.
All this being said, I also hear what Roland is saying and I do appreciate his concerns about long term durability. I fully agree that if the tuner does not know what he is doing this might be a very costly experiment hunting for that last HP. The tune should stay on the right side of conservative. This comes back to the "professionally made ECU tune" under point 2). And ideally, as DaFlake pointed out, this could be based on the existing JCW map as I quite like it: smooth and progressive.
In my own case it is the question what can be done around the area where I live - Warsaw is not exactly the place where you can find tuners with several tens of MINI ECU tweaks under their belt (though MINIs are getting more and more popular here too). So either I trust some of the local shops to do the job (there are quite a few with BMW tuning experience incl the one I pointed out in the first post) or then find some other "remote tuning" solution.
Sam
  #21 (permalink)
Old Jul 30th, 2007, 09:40 AM
DaFlake's Avatar
MMC Member
MTH is probably one of the best "remote" solutions as at least they tweak the file based on what you have and what you tell them.
  #22 (permalink)
Old Jul 30th, 2007, 09:41 AM
sam_a156's Avatar
Flying Finn
Well, originally I thought that I just wanted to have a bit more powerful car. But it ended up being quite a bit more than that - mostly because the forum and the challenge of trying to learn.
Besides, it seems to be a nice way of winding down after a tough day at the office
  #23 (permalink)
Old Aug 7th, 2007, 05:48 PM
ignote's Avatar
United States View ignote's Chili Red & Black 1st Gen MINI Cooper S Profile
Quote: Originally Posted by roland2003 (original)
hi Guys, tbh Im not suprised that removing a DFIC and (presumably poorly set up) unichip gained so much power. I bet stock ecu prog and stock intercooler would be much better. Having said that it only takes a small leak on the intercooler bellows and thats 30 horsepower out the window which could easily be (incorrectly) awarded as 'a power increase' to the next lucky tuning part fitted that happens to 'unknowingly' sort the leak at the same time.
The consequences of a poor remap are huge, it will often result in a destroyed engine. Im quite happy to declare that we would not entertain any kind of warranty claim on engine internals/detonation damage if the customer has it remapped/unichip/bluefin etc etc after a GTT conversion. ...I say that as I want peoples engines to stay together.!
- You need to ask the person mapping if they will warranty your engine internals if detonation occurs, as theyre product has more effect on that than most.
Nearly every engine I know of thats gone bang has been running remaps/piggybacks.
Yes they can be very good, but think of it as ... ..your stock mapping being 97% as good as it can be with the various other tuning parts fitted..... Now if its a 50/50 chance of improving it the last 3% OR things going bang 2 months later ...Do you still want to risk that remap?
Im confident that with our mth remaps you will get '2% of that last 3%' partly because we can relay with mth accuratly what is required and we througherly test before the car goes out. -raising the rev limit gains a couple of bhp ,but do you realy want to?
There are various ways of adjusting the fuelling..
1) injector duration (remap of altering map sensor signal to ecu with unichip or Apexi)
2) injector size
3)fuel pressure.
We can offer any of these, we have various injector sizes, adjustable fuel pressure regulators, MTH remaps , or we can fit and programme the Apexi piggyback, using wideband sensor screwed in the exhaust actually on the road with actual air cooling ,on your actual car!....
We can do the same setup procedure with the new adjustable FPR also .....
It depends what your prepared to budget for,but whatever the budget reliability must not be compromised.
Finally one tuners idea of the 'correct' AF ratio can be very different to another tuners....so be careful guys
Best Regards Roland GTT
Roland,
What would you consider a correct AF ratio? What is still safe vs stock?
  #24 (permalink)
Old Nov 7th, 2007, 04:23 PM
sam_a156's Avatar
Flying Finn
An update:
I am finally booked in for a custom/dyno ECU map for this Friday @ a local tuning shop. I decided to bite the bullet and try this out. I will also raise the rev limiter to MTH level, i.e. 7300ish...and if the shop is able to do exhaust work, I will try to get the flat section of the JCW exhaust (http://www.mini2.com/forum/engine-dr...results-8.html) fixed too.
Last time when my car was dynoed I got very similar somewhat disappointing results as Aberdeen Al documented here: http://www.mini2.com/forum/engine-dr...ad-result.html
Let's see how this goes. Will post some before/after results once I get the car back ...
Sam
  #25 (permalink)
Old Nov 9th, 2007, 03:03 PM
sam_a156's Avatar
Flying Finn
Custom tune: results
Ok, got some results - see attached file with before/after numbers and graphs.
To recap, here is my current setup:
Mini Cooper S ‘05
- John Cooper Works (JCW) 210hp Package:
Other modifications
- Mini Madness JCW intake filter kit (+flap mod)
- GTT Exhaust Manifold
- GTT +3% Overdrive Crank shaft pulley
- GTT Modified bypass valve
- GTT Intercooler + Snoot boots
Conclusions:
1) There is still something wrong with my car
- The starting point (194hp/222Nm) is some 20-30hp off from where it should be. My car produced these figures even with the JCW kit only and I would think that the manifold alone should give me some 8-10hp on top of this. I already took the car to BMW earlier after the previous dyno test and asked them to do a thorough check (S/C belt, boost, T Map sensor...), but they did not find anything.
2) Is a custom tune worth it? Well, it seems so
- While I was very disappointed with the absolute hp figures, I was pleasantly surprised with the deltas they managed to produce with the new map. Almost 10% improvement in max torque (222Nm=>241Nm) and almost +8hp max power. The latter is in the same magnitude with a manifold! Perhaps more important than the max figures are the improvements in lower end of the curve - the deltas there seem to be even bigger than the max deltas.
It has been raining cats and dogs today, so much for a good test drive. But from what I could tell at least the throttle response was much sharper and the car felt better (no flat spots, hesitation). Did not manage to raise the rev limiter nor fix the exhaust. Let's see if I get these done next week.
...but...ggrrrrrr I still do not know what to do to find those missing 20-30 horses. Do I have to drive all the way to UK (again) to find somebody who could pin point the problem?!?
Sam
  #26 (permalink)
Old Nov 9th, 2007, 03:20 PM
alski's Avatar
dyno-mite, might not....
Local Time: 08:14 AM
England Male View alski's Classified Ads
how much did you pay for your tune sam?
carefree
  #27 (permalink)
Old Nov 9th, 2007, 03:37 PM
sam_a156's Avatar
Flying Finn
Alski - PM sent!
  #28 (permalink)
Old Nov 9th, 2007, 03:40 PM
MINI 2 Sponsor GT Tuning
United Kingdom View roland2003's Classified Ads
Some possibilities for you Sam..
- Down on compression
-Down on boost ...air leak .
-Restrivtive air filter (power drops away a bit early ooking at the graphs)
- Bypass valve spring broken which losses boost
-Conservative RR, or one with inadequate fans...you need to monitor the intake temp off the OBD2 port and say your not happy if they cant keep it below say 40 deg C
GTT Crank pulley gives only about 4bhp top end but a nice increase across the mid range.
Manifold? Not sure on your setup but the JCW Motorsport one gains 3bhp on a GP......... I do know that.
-JCW210 is typically are about 195-197bhp not 210bhp .
It may be a 'little bit of everything' rather than one thing.
  #29 (permalink)
Old Nov 9th, 2007, 07:12 PM
sam_a156's Avatar
Flying Finn
My air filter should be cleaned, that has been on my todo list...might well do that over the weekend. Perhaps will regain one or two HPs, who knows
I will also next week get the winter tires changed at the BMW dealer - will go there with a new checklist. Maybe there really are multiple small things...
Fully agree with Roland's view of JCW cars under performing. My car made 192.5hp/221Nm already last December just after the installation of JCW kit (without any other mods) on the very same dyno and with the same dyno operator (old image attached). Though this was with 205/45/17 run flat winter tires vs. today with 215/40/17 Eagle F1s - so not 100% comparable.
I have a head and a cam planned for early next year. I would just like to sort out the existing mods before that.
What have others tested with similar setup? About 220hp I reckon?
On the positive side, at least made some progress today - the local guys seem to know their ECUs!
Sam
Name:	Sam MCS JCW-Dec06.jpg
  #30 (permalink)
Old Nov 9th, 2007, 08:33 PM
United Kingdom View johnlondonw3's Dark Silver & Black 1st Gen MINI Cooper S Profile
Smile
Whats MTH ?
Tags: ,
ECU remaps Grabber First Generation MINI Tuning 0 Apr 21st, 2006 11:08 AM
ECU Remaps GTT 280 First Generation MINI Tuning 6 Dec 25th, 2005 04:01 PM
ECU Remaps in Canada? Gordonh First Generation MINI Tuning 2 Oct 5th, 2005 08:03 PM
importance of break period Rogier First Generation CVT & Automatic 1 Jun 3rd, 2004 11:33 PM
