| Whose that then Jamie? First M45 Cooper S to run a 12 (12.96@105) On Nitrous 11.16@123 0-100 7.1991 ![]() http://www.1320MINI.co.uk |
| The team leader of the calibrations and emmissions department where I work, he is probably the most experienced calibration engineer in the UK, and probably in the top 20 in the world. Experience counts for so much in this field and his tunes are currently in use on around 200000 engines! |
| Congrats on the new found trq Sam What octane rating petrol do you have out there? Did they take the car to the rpm limiter on each run?? If they tuned the ecu they should be able to tell you what the timing was doing at each rpm point and what the intake temps were. Looking at the plot it looks like the Intake air temps were to high and the timing was retarding, if they were staying on the throttle to the rpm limit that is one of the worst I've seen up the top end espically in comparison to the JCW dyno sheet, also notice that the trq is about 10 down at 2000as well in comparison to the JCW. First M45 Cooper S to run a 12 (12.96@105) On Nitrous 11.16@123 0-100 7.1991 ![]() http://www.1320MINI.co.uk |
| Can he move my rpm limit to infinity and beyond First M45 Cooper S to run a 12 (12.96@105) On Nitrous 11.16@123 0-100 7.1991 ![]() http://www.1320MINI.co.uk |
| Thx! (though hard to celebrate as the absolute figures are still far off from the mark... )Fuel: Shell V-Power Racing 99. Rev limiter: to my knowledge, yes. But the 2nd higher run looks suspicious, it looks as if the rev limiter hit already at 6600 or thereabouts (or they did not stay on the throttle all the way) . Will talk to them about this next time when my rev limiter will be raised. Note. If you look at the average HP and torque figures ("srednia moc/moment"), they were actually better in the JCW-only run last year than in the pre-ECU tune run yesterday!? With all the mods I have done after JCW... So there is def still something weird going on and it is not the ECU this time. |
| Hi sam, a common error on RR's is calibration of the RPM to roller speed (mph ). The best way is if the RR software is able to link to the cars ecu through OBD2 link , that way its bang on. The way alot of RR operators do it is to hold it at 3000rpm in whatever gear your using on the rollers and enter that. ....there is scope for error doing it this way. Power v rpm on the plot will then be wrong. Are they correcting for ambient temp/ambient pressure and charge air temp. Or have they got a fan that replicates 'on the road' charge air temps? |
| Nope you are not! ![]() The car was fine last summer after GTT visit. But then the clutch started to expire and after the clutch change job (under warranty at dealer) it started to get progressively worse. It was still quite ok at WOT and higher revs, but hesitation/stuttering at lower end. Bad fuel consumption (up to 15-16L/100km or 17.5-19mpg in heavy Warsaw traffic ). Oh, and I forgot to mention: one of the symptoms is that it does not run well when cold right after starting the engine - needs plenty of revs to get going.I was driving it yesterday in a torrential rain so can't really be so sure, but from what I could tell it felt much more responsive and smooth now. Another test drive planned for today |
| Oh, that must be it. In fact I saw him doing that before the actual run: revving the car to about 3-4k rpm. That explains the "shifting" of the curve on the 2nd run. To my knowledge no ambient temp/ambient pressure corrections were applied. They naturally have a fan, but I seriously doubt it would adjust the air temp. The thing is, that you have to appreciate that I have a little communication problem with the local folks as my Polish is limited to ordering in a restaurant...and their English (not to mention Finnish) is likewise often not very fluent. When tuning using the sign language things may get lost in translation. |
| Some stuff you want to log when running on a dyno Roland mentioned some of this RPM. Use a RPM pick-up as the OBD port is slow. While you can run diagnostics off it, it's slow so it's hard to get as many data points as you want. IATs this is the largest indicator of repeatable runs. If this starts to climb, your power will drop. If it climbs a lot, you will loose tons of power, as eventually the ECU will dump fuel to cool combustion. Timing. Watch the timing. On dynos, it's pretty easy to get some timing retard. While there are signatrues in the dyno curve, it's best to get this data so that you can SEE if you get some retardation in timing. The knock sensor loop will pull timing very agressively if it detects anything, and then your power will go down the toilette. Also, knowing total advance at red-line can be a way (even without pull) to look at car to car variations. Manifold pressure. While not that importante per se, you should see about as much MAP pressure (boost plus atmostpheric pressure) on each run, and this can be a tell if your starting to leak or the bypass valve isn't closing fully. Gear you run in. Different gears turn different parts of the drivetrain at different rates for a given RPM. This will lead to different effective masses. There is no right gear here, but you should do it in the same gear if you want to compare. And lastly, depending on the dyno you use, the RPM ramp speed. If it's an inertial, you're just stuck with how fast the speed changes. But if it's a dynamic load dyno, a faster RPM ramp will show lower HP than a slower RPM ramp. This has to do with the energy in the rotating parts, and how much time it takes to get those parts to speed. Matt |
| Tags: ecu, remap |
| ECU remaps | Grabber | First Generation MINI Tuning | 0 | Apr 21st, 2006 12:08 PM |
| ECU Remaps | GTT 280 | First Generation MINI Tuning | 6 | Dec 25th, 2005 05:01 PM |
| ECU Remaps in Canada? | Gordonh | First Generation MINI Tuning | 2 | Oct 5th, 2005 09:03 PM |
| importance of break period | Rogier | First Generation CVT & Automatic | 1 | Jun 4th, 2004 12:33 AM |
